OxygenOS Oneplus 6 recovery lacks basic functionality
  1. DrRambone
    Froyo May 24, 2018
    DrRambone , May 24, 2018 :
    You lying, there is not
  2. xnutzii
    Lollipop May 24, 2018
    xnutzii , May 24, 2018 :
    You definitely sure about that? Could you take a picture with another phone to clarify this? Because even my 5T has the Install option.
  3. DrRambone
    Froyo May 24, 2018
    5 T has, op6 dont, check xda for more witnesses about the crippled recovery
  4. xnutzii
    okay, wait a second.
  5. xnutzii
    can't find anything on xda tho
    prajnay0 likes this.
  6. DrRambone
    Froyo May 24, 2018
  7. xnutzii
  8. DrRambone
    Froyo May 24, 2018
    Again, i try to get an reply from oneplus why they shipped it with shitty recovery.
    I will install twrp when its released but for now anyone bricking their phone will be out of luck
    G_plusone likes this.
  9. xnutzii
    You can install the recovery now, (at least i suppose.) Download a tool called "tool all in one" there you can install the twrp recovery for the 6.
  10. DrRambone
    Froyo May 24, 2018
    No, there no twrp for op6 yet
  11. xnutzii
    have you tried it with the tool yet?
  12. anupritaisno1
    KitKat May 24, 2018
    anupritaisno1 , May 24, 2018 :
    That's because the op6 probably moved to A/B system partitions. The recovery on A/B devices is useless as the updates happen while the system is running. The only thing that the recocere you have can do is wipe data
  13. anupritaisno1
    KitKat May 24, 2018
    Twrp can probably no longer be flashed with fastboot
    G_plusone and xnutzii like this.
  14. xnutzii
    that would be VERY bad. I always rooted my phones, and that would even be a reason for me to skip the 6...lol
  15. Floraien
    Cupcake May 24, 2018
    Floraien , May 24, 2018 :
    Hey Guys,
    I'm the one who killed his phone cuz of lack of recovery.
    I installed the Android P beta, missed the face unlook feature and wanted it back, so I installed the Oxygen OTA and everything seems fine. I started my phone, got to the startmenue where you have to connect to your wifi. After that I reached the part where it searches for Updates and boom. The update searcher just crashs and it redirects me back. Just stuck in this shitty startup menue...
    I think I'll kill myself?
  16. DrRambone
    Froyo May 24, 2018
    There is an rescue:
    Download the extracted img from ota: https://androidfilehost.com/?fid=674106145207488478
    Flash each file with fastboot, should be ok.
  17. Floraien
    Thanks but:
    If its the first time you start your phone you are in this wierd startup menue. And I'm stucked in this menue. Not shure how I would be able to download something or flash :(
  18. DrRambone
    Froyo May 24, 2018
    Press volume up and power to enter fastboot
    #38
  19. Floraien
    Ok, now I'm in fastboot menue. What next?
    #39
  20. DrRambone
    Froyo May 24, 2018
    Download the files i linked to, make sure you have adb installed:
    https://forum.xda-developers.com/oneplus-6/how-to/oneplus-6-unlock-bootloader-flash-twrp-t3792643
    ADB and Fastboot Drivers Installation
    1. Download & Update OnePlus 6 Drivers From Here
    2. Download & Update Fastboot and ADB Binaries/Drivers from Here
    3. Run the .exe file downloaded from above as Administrator.
    4. Press 'Y' every time the installer asks for.
    5. Continue Driver Installation.
    Now, ADB and Fastboot have been installed on your PC and should be Working as desired."
    Turn the phone off. Then boot it into fastboot mode by holding volume up + power or select reboot to bootloader if advanced reboot is activated via developer options. The phone will display "fastboot" text indicating that it has successfully entered fastboot mode.
    Plug the phone into your PC, then open a command prompt window on the desktop (Shift + Right Click -> Open Command Window here) and type:
    Code:
    fastboot devices
    This command will list the connected devices. If your phones serial number shows up you are good to go and may continue. If the phone is NOT listed this indicates that your drivers are not installed correctly. In order for you to continue you must fix your drivers so that your phone is listed under fastboot devices."
    Extract the img files to an folder, navigate to that fold in cmd, install each img by:
    fastboot flash aop aop.img
    fastboot flash bluetooth bluetooth.img
    fastboot flash boot boot.img
    fastboot flash dsp dsp.img
    fastboot flash dtbo dtbo.img
    fastboot flash fw_4j1ed fw_4j1ed.img
    fastboot flash fw_4u1ea fw_4u1ea.img
    fastboot flash LOGO LOGO.img
    fastboot flash modem modem.img
    fastboot flash oem_stanvbk oem_stanvbk.img
    fastboot flash qupfw qupfw.img
    fastboot flash storsec storsec.img
    fastboot flash system system.img
    fastboot flash vbmeta vbmeta.img
    fastboot flash vendor vendor.img
    #40
