OxygenOS Oneplus 6 recovery lacks basic functionality
  1. DrRambone
    Froyo May 24, 2018
    #41
    Floraien likes this.
  2. Floraien
    Cupcake May 24, 2018
    Floraien , May 24, 2018 :
    The phone is listed! And now?
    #42
  3. DrRambone
    Froyo May 24, 2018
    DrRambone , May 24, 2018 :
    Extract the img files to an folder, navigate to that fold in cmd, install each img by:
    #43
  4. Floraien
    Thank you so far but, the file won't download. Also I'm not able to remote flash the oneplus oxygenOS.
    #44
  5. anupritaisno1
    KitKat May 24, 2018
    anupritaisno1 , May 24, 2018 :
    It's going to be this way on all new phones
    Many phones don't even have a recovery anymore. At least oneplus put efforts to make one
    #45
  6. xnutzii
    Lollipop May 24, 2018
    xnutzii , May 24, 2018 :
    shit...But you're right. At least they put some effort to make a recovery.
    #46
  7. anupritaisno1
    KitKat May 24, 2018
    Btw I'm really happy that we have a vbmeta partition. This means that we can flash custom ROMs on locked bootloaders. It won't be easy but this partition makes it possible
    #47
    G_plusone and BeingIncog like this.
  8. Floraien
    So finally I got the file. I tried to flash the .img on the phone but the comand says:
    FAILED (remote: Flashing is not allowed in Lock State)
    finished. total time: 0.011s
    #48
  9. geo07
    Ice Cream Sandwich May 24, 2018
    geo07 , May 24, 2018 :
    I have a question, in op6, if I copy the original 5.1.5 zip rom into the phone, do I still have the option to flash it through Settings, System updates- local upgrade as before?
    #49
  10. DrRambone
    Froyo May 24, 2018
    Your bootloader is locked, i have no idea if it can be unlocked in the state your op6 are in.
    Maybe any oneplus experts has some idea?
    #50
  11. jinman11
    Donut May 25, 2018
    jinman11 , May 25, 2018 :
    Hey DrRambone. Thanks for your helpful posts. I've downloaded all the img files and they all flash, except for the 2 big ones "system" and "vendor" because fastboot says they're too big, so I think I was able to use sparse to load them with a smaller download size:
    fastboot flash -S 400M system vbmeta.img
    So I think I got them all flashed, but now, nothing happens, I relocked the bootloader, reboot the phone, and it's just a black screen after a couple "Powered by Android" screens.. the status LED is on though
    #51
  12. jinman11
    Donut May 25, 2018
    when you boot to fastboot, you can just enter "fastboot oem unlock" on your computer and it will give you a prompt on your phone to unlock it.
    #52
  13. jinman11
    Donut May 25, 2018
    What is this tool you're talking about?
    #53
  14. xnutzii
    Lollipop May 25, 2018
    xnutzii , May 25, 2018 :
    it's called "tool all in one" i rooted my oneplus phones easily with that.
    #54
  15. azhang
    Cupcake May 25, 2018
    azhang , May 25, 2018 :
    Quick question. I'm essentially in the same situation - bricked phone, except it's a Chinese version running HydrogenOS. I manually extracted the .img files from the latest HydrogenOS .zip, and ended up with a few .img files that aren't included in your list (eg. I have an abli.img, devcfg.img). Should I go ahead and flash them all anyways, in order as they appear in my extracted folder? ie. Does the order you gave matter, and do the extra .img files I have matter?
    Thanks, trying not to mess up the phone anymore haha.
    #55
    G_plusone likes this.
  16. Floraien
    Floraien , May 25, 2018 :
    noupe, nothing is happening on my phone
    #56
  17. jinman11
    Donut May 25, 2018
    So, your phone is booted to fastboot, you can see the fastboot menu on the screen? Your phone is connected to your computer?
    If you open a command prompt and type "fastboot devices", does it show your phone's serial number?
    #57
  18. Floraien
    Yes id showed the serial number. I get a new one. Thank you anyway. <3
    #58
