105
[OnePlus 6][ROM][OTA][Oxygen OS] Mirrors for official Oxygen OS ROMs and OTA updates
  1. masi0
    Gingerbread May 23, 2018
  2. FlaxenFlames
    Cupcake May 23, 2018
  3. codemsi
    codemsi , May 23, 2018 :
    Hi,
    I'm getting myself a oneplus6 with hydrogen OS, but i intend to flash is to oxygen os.
    Can someone explain what is "Signed flashable zips" and "OTA incremental update zips"??
    Also, what does the stock recovery image do OR what is it use for?
    So basically, if i wanna flash it to oxygen OS, which one do i download? or do i have to download multiple images?
  4. kaihp
    Jelly Bean May 23, 2018
    kaihp , May 23, 2018 :
    The "signed flashable zips" are full images, ca 1.7GB in size. The incremental zips will bring you from version X to X+1 and are much smaller in size (e.g. 20-60MB).
    The Recovery image is a small self-contained program which allows you to flash/upgrade the OS itself. You can't upgrade the OS while the OS is running ;)
    Read the post by @Funk Wizard in the "Oneplus 6 3rd party Development" section:
    OnePlus 6: Unlock Bootloader | Flash TWRP | Root | Nandroid & EFS backup.
    idkwhoiam322 and Alvie like this.
  5. SomeSayImHandS0me
    Honeycomb May 23, 2018
    SomeSayImHandS0me , May 23, 2018 :
    are these official images from oneplus?
  6. SomeSayImHandS0me
  7. CYB3R0ID694
    CYB3R0ID694 , May 23, 2018 :
    Yes..
  8. SomeSayImHandS0me
  9. Spannaa
    KitKat May 23, 2018
    biafra and Titokhan like this.
  10. Titokhan
    Titokhan , May 23, 2018 :
    @codemsi
    Get the latest full signed zip (5.1.5 ATM) and flash from recovery or do a local upgrade.
    Actually you can, as OnePlus 6 supports seamless update due to A/B partitioning.
    @SomeSayImHandS0me
    Obviously.
    @Spannaa
    Thanks for your contributions, as always.
    @ Others
    I've decided to remove the stock recovery section as /recovery is now fused with /boot due to A/B partitioning. You need to reflash stock boot.img (in both slots) to get stock recovery back.
    Spannaa likes this.
  11. saintxseiya2
    saintxseiya2 , May 23, 2018 :
    @Titokhan
    I have tried to replace the 5.1.5 boot.img with a patched one, but now i can't install OTA, there is no ADB or flashing option in the recovery. Any help?
  12. Titokhan
  13. kaihp
    So with the OP6, we will have to flash a custom TWRP recovery to both boot_a and boot_b partitions? (when it arrives, that is)
  14. codemsi
    Cupcake May 24, 2018
    codemsi , May 24, 2018 :
    So basically in order to get my new phone working as it should, i shld flash my OP6 with the 5.1.5 signed flashable zip only?
    Do i have to download and place the recovery image?
  15. baadnewz
    Froyo May 24, 2018
    baadnewz , May 24, 2018 :
    Does anyone have Oxygen OS 5.1.0 for OP6? I'm happy just with boot.img and system.img thanks
  16. kaihp
    Jelly Bean May 24, 2018
    kaihp , May 24, 2018 :
    You are correct. You can either download and flash the full OS, the v5.1.5 signed flashable ZIP, or flashing the OTA update that updates you from your current version (5.1.0 or 5.1.3) to 5.1.5.
    Unless you want to replace the original boot/recovery with a custom one (TWRP), there is no need to update it.
  17. Titokhan
    Honeycomb May 24, 2018
    Titokhan , May 24, 2018 :
    As a consequence, a new section for stock boot (& recovery) images is added.
  18. jinman11
    Donut May 24, 2018
    jinman11 , May 24, 2018 :
    Thanks for the info. When I try to flash the 5.1.5 ZIP (fastboot update xxx.zip) it tells me:
    archive does not contain 'android-info.txt'
    archive does not contain 'android-product.txt'
    error: update package has no android-info.txt or android-product.txt
    Any idea what that means?
    #38
  19. F_Ilya_Kushnir_owKC
    F_Ilya_Kushnir_owKC , May 24, 2018 :
    This image NOT for fastboot. Go to the system update menu and apply it there.
    #39
  20. jinman11
    Donut May 24, 2018
    I'm on Hydrogen OS right now, I don't think I can do that.
    #40
    Ghazi_Marzouk likes this.
