164
[OnePlus 6][ROM][OTA][Oxygen OS] Mirrors for official Oxygen OS ROMs and OTA updates
  1. kaihp
    Jelly Bean Feb 7, 2020
    Artemus. likes this.
  2. kaihp
    kaihp , Feb 7, 2020 :
    Wrong thread - ask in the release thread and report under feedback.
    Mod: please close thread
    Artemus. and Caomhin like this.
  3. Ciprian_badin
    Cupcake Feb 7, 2020
    Chosen_One likes this.
  4. kaihp
    Then why did you ask "please link"? o_O
  5. Ciprian_badin
    Cupcake Feb 7, 2020
    Ciprian_badin , Feb 7, 2020 :
    me ? please check again . I didn't post anything about a link
  6. Caomhin
    Community Hero 2020 Feb 7, 2020
    Caomhin , via OnePlus 6T , Feb 7, 2020 :
    What specific differences, they are the exact same update file, no difference.
    And as I mentioned you can do a full format reset to refresh the phone.
    If you wish to downgrade, the link I provided will show you how to do that, as per @ironass post within that link to the thread.
    Artemus. and ironass like this.
  7. kaihp
    Jelly Bean Mar 3, 2020
    burnout123 and Artemus. like this.
  8. narceoneplus2
    Ice Cream Sandwich May 8, 2020
  9. A1535567578018
    Cupcake May 11, 2020
  10. Muhammad_Kashif_bahl
    Honeycomb May 11, 2020
    kaihp likes this.
  11. B1541810498046
    Cupcake May 18, 2020
    B1541810498046 , via OnePlus 6 , May 18, 2020 :
    my OnePlus 6 run on Android 9 .my issue is that my device new update in device system and I downloaded .But while installing update after ,99% system say error in install.how to solve this issue . please help me..thank u
  12. Caomhin
    Community Hero 2020 May 18, 2020
    Caomhin , via OnePlus 6T , May 18, 2020 :
    B1541810498046
    my OnePlus 6 run on Android 9 .my issue is that my device new update in device system and I downloaded .But while installing update after ,99% system say error in install.how to solve this issue . please help me..thank u​
    You need to be on Stable build 9.0.9 for OP6, it was the last Stable 9 version, but contained update files in order to update to any version of Android 10.
    There should be no Data loss, however It is always Good practice to Backup your phone before doing any of the following.
    Go to the link below, download Android 9.0.9 and install manually, it's a later build than Beta 25,so there should be no data loss, it will be an upgrade over Beta 25.
    https://oneplusupdates.com/device/oneplus-6
    You will then be able to update to Stable. Follow the instruction on the OnePlus Support website below.
    https://www.oneplus.com/support/softwareupgrade
    Artemus. and B1541810498046 like this.
  13. B1541810498046
    thank u
    Caomhin likes this.
  14. amangera29
    Froyo May 21, 2020
  15. Caomhin
    Community Hero 2020 May 21, 2020
  16. amangera29
    Froyo May 21, 2020
  17. ironass
    Lollipop May 21, 2020
    ironass , May 21, 2020 :
    No need to extract any files.
  18. Caomhin
    Caomhin , via OnePlus 6T , May 21, 2020 :
    Edit the filename in a file manager and remove the .jar from the end of the file, it will work fine. Make sure the file is moved outside of any folders into your Main root storage
  19. LG18700
    Cupcake May 23, 2020
    LG18700 , May 23, 2020 :
    Is this only for rooted One Plus phones or are they files you can download and install on the handset?
  20. Artemus.
    Community Hero 2020 May 23, 2020
    Artemus. , May 23, 2020 :
    kjjm, Caomhin and LG18700 like this.
