98
[OnePlus 6][ROM][OTA][Oxygen OS] Mirrors for official Oxygen OS ROMs and OTA updates
  1. YudhPK Donut May 24, 2018
    #41
  2. Ghazi_Marzouk Donut May 25, 2018
    #42
  3. drmilav Donut May 25, 2018
    drmilav, May 25, 2018 :
    oxygen os 5.1.5 full ota available on one plus site now but there is no corresponding recovery available also there is no option to load ota from recovery.
    #43
    kaihp likes this.
  4. Yannis Neris Ice Cream Sandwich May 25, 2018
    Yannis Neris, May 25, 2018 :
    Did you try through local upgrade?...
    #44
  5. Ghazi_Marzouk Donut May 25, 2018
    Ghazi_Marzouk, May 25, 2018 :
    I don't know from where to start. Local upgrade ? Means what
    #45
  6. Yannis Neris Ice Cream Sandwich May 25, 2018
    Put the rom in your internal storage
    Go to settings >system update> local upgrade
    #46
    Deactivated User likes this.
  7. Ghazi_Marzouk Donut May 25, 2018
    I will try it ! Thank you [e]1f60a[/e]
    #47
  8. Ghazi_Marzouk Donut May 25, 2018
    Verdict: I tried the method described on the download page on the Oneplus website. I successfully installed the OxygenOS.but...
    Hydrogen OS have more functionality and the most is the built in call recorder and a tool for clearing data (like app cache). OxygenOS have more app belonging to google, but it's easy to download from the playstore and there is some google app that I don't use.
    So I will be back for the HydrogenOS and hope that you can have a try
    #48
  9. SomeSayImHandS0me Honeycomb May 25, 2018
    #49
  10. Spannaa KitKat May 25, 2018
    Spannaa, May 25, 2018 :
    OnePlus have never provided OOS fastboot images.
    #50
  11. G_Rocko_Bauer_ggQE Cupcake May 25, 2018
    #51
  12. SomeSayImHandS0me Honeycomb May 26, 2018
    SomeSayImHandS0me, May 26, 2018 :
    well one plus one days they always have. now I had to unpack the payload.bin file. to do clean install via fast boot
    #52
  13. Spannaa KitKat May 26, 2018
    Spannaa, May 26, 2018 :
    You're right - there were fastboot images for the OnePlus One, but they weren't OOS and they weren't provided by OnePlus.
    The official rom for the OnePlus One was Cyanogen OS (COS) which was provided by Cyanogen Inc.
    #53
  14. T1527305969660 Eclair May 26, 2018
    T1527305969660, May 26, 2018 :
    I have successfully changed from HydrogenOS to OxygenOS. I downloaded the signed zip from this thread and upload to the phone. 1st, I tried the power+vol down but this didn't work..no option to load the zip file.. I tried 2nd option from Settings ->System Update -> Local Upgrade and this works... BUT not yet as I found out Google can't login... then I just need to factory reset and all are okay now... Hope this helps..
    I also like to applaud the services of JD (China), I ordered 10.am and it was delivered same day 4pm!
    and of course, super thanks for uploading the zip file alI found on this thread.. really helpful as no official file yet in the website..
    #54
    5star02707 and manuelblanco like this.
  15. SomeSayImHandS0me Honeycomb May 26, 2018
    best way to convert is manually via fastboot
    #55
  16. T1527305969660 Eclair May 26, 2018
    Not tried that . Anyway, local upgrade worked.. thanks.
    #56
  17. x8xx8x Gingerbread May 28, 2018
    x8xx8x, May 28, 2018 :
    what
    what are the differences between hydrogen os and oxygen os on the op6?
    #57
  18. kaihp Jelly Bean May 28, 2018
    kaihp, May 28, 2018 :
    HydrogenOS is for China, OxygenOS outside China. I think the biggest difference is HOS has no Google Apps, but there are some other major difference.
    #58
  19. x8xx8x Gingerbread May 28, 2018
    no. sorry. i guess my question wasnt clear enough.. ive used used hydrogen os on the op2 & 3. i haven't since. im just curious to know if there has been any major changes with hydrogen os since?. back when i used it the battery life on it was really really good. id like to make the switch to that if its still as good
    #59
  20. kaihp Jelly Bean May 28, 2018
    I have never used HydrogenOS, so I have no idea. You probably need to make your own informed decision.
    #60
