9
oneplus 6 slow motion
  1. Someshwar Sharma
    Cupcake May 22, 2018
  2. vwite
    Honeycomb May 22, 2018
    vwite , May 22, 2018 :
    they should clarify this on their advertising so people know before purchasing, it is disappointing for a lot of people
    Terryruiz likes this.
  3. sandesh2007
    Eclair May 22, 2018
    sandesh2007 , May 22, 2018 :
    yaa you are correct. never some one would have imagined it will be so bad.
  4. kumaryashwin
    Jelly Bean May 22, 2018
  5. Siddharth singh parihar
    Siddharth singh parihar , May 22, 2018 :
    Facing the same issue even in 720p mode in OnePlus 6, there is no light at all. Never faced this issue in OnePlus 5. It is too dark to see anything.
  6. V1527003353813
    V1527003353813 , May 22, 2018 :
    same issue here. slow motion in op6 is very dark. Tried with 1080p with much lesser fps of 240 and it's still quite dark compared to normal video. Higher FPS is just terrible.
    understand that it gets very little time per frame to get enough light on the sensor but even then it's much darker compared to slow motion vdo taken in other phones. tried with Honor 8 pro and iPhone 7 plus, one having much lesser price and one much higher price
    I turned off the auto brightness in all the three phones and tried.
    so there is definitely some issue here with one plus 6.
  7. L1527005751259
  8. zizanieandco
    zizanieandco , May 22, 2018 :
    Hello, how do you active/use slow motion.i don't see the option on vidéo mode on my opo6. Thanks
  9. nid92
  10. sandesh2007
    Eclair May 22, 2018
    you need to update to latest software
    L1527005751259 likes this.
  11. Loonymoon
    Froyo May 22, 2018
    Loonymoon , May 22, 2018 :
    the shutter speed has to be very fast, switch the phone to to manual aettings still mode and see what shutterspeed you require to get a decent exposure . I bet it's longer than 1/250 sec that you'd need for 250 FPS.
  12. shanavin
    shanavin , May 22, 2018 :
    update your phone
  13. shanavin
    pretty disappointing, the slow motion video is blurred and noisy even when you have normal light..this is not low light issue.. OnePlus 6 need to fix this.
  14. zizanieandco
  15. Kkautuk
    Donut May 23, 2018
    Kkautuk , May 23, 2018 :
    (pink borders when scrolling in minimum brightness)
    There is an appearance of a slightly pinkish border around top and bottom edges of images when scrolling. This is most noticeable when there's a dark/black image.
    this gets even prominent when in reading mode.
    I tried capturing it in screen record but it's not visible there.
    this issue gets resolved on increasing brightness
    is someone else facing this?
    (sorry I did not have enough points to start a new thread)
  16. Pranav. Cherayi
    Cupcake May 23, 2018
    Pranav. Cherayi , May 23, 2018 :
    if you need to take slow motion videos it should be a well light place because number of frames that capturing is increasing.its not a bug
    gaurangpathakk likes this.
  17. Koulini
  18. inffy
    KitKat May 23, 2018
    inffy , May 23, 2018 :
    As said already the slowmotion needs a great light conditions to actually look good. It will look like that if you try to do it inside.
    It is the same with the samsungs, sonys etc slowmotion
    #38
  19. karthikmohan_
    Froyo May 23, 2018
    #39
  20. Someshwar Sharma
    #40
