Battery/Charging OnePlus 6 wont charge with non dash cable
  1. Nunofcp
    Cupcake Jun 5, 2018
    Nunofcp , Jun 5, 2018 :
    Oneplus 6 won't charge with non-proprietary cable.
    Forgot my cable at home, had a USC C type cable that worked before with my Oneplus 5, but I have tried with differnt power outlets, even different cables with Oneplus5 works but not with Oneplus 6.
    Should be corrected, sometimes you forgot the dash cable, shouldn´t be the only way to charge your phone. Now Im going to be a week without phone....Frustating
    Any tips I appreciate it.
  2. Tobikage
    Nougat Jun 5, 2018
    Tobikage , Jun 5, 2018 :
    I find it a little hard to believe that. o_O
  3. G_Sai_Raina_syku
    Jelly Bean Jun 5, 2018
  4. the_o2
    User of the Year 2018 Jun 5, 2018
    the_o2 , Jun 5, 2018 :
    Sounds like iPhones..
    Maverick2.0 likes this.
  5. Ether
    Eclair Jun 5, 2018
    Ether , Jun 5, 2018 :
    My OP6 works fine with Anker, and a number of other random 3rd party cables I've tried.
  6. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jun 5, 2018
    NeVeR_SeTTLe , Jun 5, 2018 :
    Mine charges with a non-proprietary cable :)
  7. EDIflyer
    Gingerbread Jun 5, 2018
    EDIflyer , Jun 5, 2018 :
    Mine works with every cable I've tried, including lots of MicroUSB with USB-C adapter on the end - in fact I hardly ever use Dash charger or cable!
  8. pgrey
    Ice Cream Sandwich Jun 8, 2018
    pgrey , Jun 8, 2018 :
    @Nunofcp Reboot, and it'll work.
    I have the same issue, and I can charge one(1) time, before I have to reboot again, with a non-dash charger (tried a whole variety of power sources, all work fine on my wife's 5T).
    If I reboot, it'll charge from any of them, one time, until I reboot again.
    You can also leave it in Safe Mode, and it'll work repeatedly, but it's not a great thing for daily phone use.
    The "time since last charge" never resets too, on a 2nd, 3rd, etc charge, it's values like "1d 4h since last charge", but 100% charged, or "2d 3h", it's a bit comical looking, somehow I used my phone for 2+ days, and never lost a bit of charge ;-]
  9. pgrey
    @Tobikage This is exactly what I thought. They have a BUNCH of s/w related issues related to charging, this being one of them (only able to charge one time, from non-Dash, then need to reboot to charge agian).
  10. Arthur.orin
    Gingerbread Jun 8, 2018
    Arthur.orin , Jun 8, 2018 :
    maybe that replacement cable u tried is the problem. try to isolate the issue. unless ur in a remote location. am sure u can buy USB C there.
    EDIflyer likes this.
  11. tfarley01
    Froyo Jun 8, 2018
    tfarley01 , Jun 8, 2018 :
    Mine charges fine, just slower. It just wont Dash charge with non Oneplus cables.
  12. CosmoK
    Eclair Jun 8, 2018
    CosmoK , Jun 8, 2018 :
    Same here, charges without problem with non-original charger and cable.
  13. pgrey
    Ice Cream Sandwich Jun 9, 2018
    pgrey , Jun 9, 2018 :
    There's a lot of issues in charging, if you ask me, currently, that were fine in the 5T (which makes me wonder, a little, about how they do their code merges/integrations).
    The fact my "time since last charge" will only change if I reboot, is interesting too. Clearly the battery message queue has some issues, probably in BATTERY_PLUGGED_USB, or BATTERY_PROPERTY_STATUS, if I had to guess, the battery queue in Android is "interesting" ;-]
  14. Kar Wong
    Cupcake Jun 10, 2018
    Kar Wong , Jun 10, 2018 :
    hi guys! i cannot create a thread yet cause im new but i got a question, i just got an one plus 6 china rom but flashed with global rom, it comes with china 2 pin charger, but i live in Malaysia which using 3 pin (UK) charger, so if i buy a original UK 3 pin dash charger, and use it on my china rom one plus 6, would it work?
  15. EDIflyer
    Gingerbread Jun 10, 2018
    EDIflyer , Jun 10, 2018 :
    Yes, as long as it's a OP Dash charger/cable and OP phone it should work fine.
    Kar Wong likes this.
  16. Bollux
    Bollux , Jun 10, 2018 :
    Yes it does, you should try to get a good one and not those 1$ cables
  17. smunro622
    smunro622 , Jun 10, 2018 :
    USB C cables are not all the same, I buy the high quality from Anker and that's it. I am new and it is hard to believe it won't charge, may you bought a non compliant usb c cable that is faulty?
  18. PiTRiS87
    Gingerbread Jun 27, 2018
    PiTRiS87 , Jun 27, 2018 :
    Same issue here. Not charging with oem cables, only with original one... Tried a few different ones that all worked with OP3T, but no success...
  19. PiTRiS87
    Oh, ok, my bad, the phone is charging (red led is on and battery percentage is increasing), but no indication on the battery display is shown. That's what was confusing... So just an UI bug...
  20. razbensimon
    Cupcake Mar 13, 2019
    razbensimon , Mar 13, 2019 :
    Will I get a “fast charge” on OnePlus 6T, using any USB Type-C cable (with 56k resistor) and Original Dash Charger?
