oneplus 6t android auto issues
  1. Samartel Cupcake Jun 13, 2019 at 1:17 PM
    Samartel, Jun 13, 2019 at 1:17 PM :
    Got my new 6t to upgrade from my 5, pretty happy about it except for Android Auto. To be clear, my 5 works perfectly with Android Auto.
    My 6t will not integrate, Spotify, Audible or any other app with Android Auto. Yes, I have uninstalled and reinstalled. I even went through Android Auto to select the apps and installed them, tried the battery optimization trick. Nothing. pretty frustrating that this doesn't work considering I spend a lot of time in my vehicle.
    Anyone have any issues as well??
    OS 9.0.14
    Build A6013_41_190528
    Thanks in advance
    Steve
  2. GuidoNervi Gingerbread Jun 14, 2019 at 9:12 AM
    GuidoNervi, Jun 14, 2019 at 9:12 AM :
    hello,
    if you connect AA through USB cable, try to force "transfer file" mode under USB developer mode. For me that was the trick.
    should be wonderful if someone had success using AA only on WIFI.
    Regards
    Samartel likes this.
  3. Samartel Cupcake Jun 14, 2019 at 12:36 PM
    Samartel, Jun 14, 2019 at 12:36 PM :
    Thanks a lot for the reply. Is there any way you could give me a little bit of help on doing that? Just a little instruction would be great.
    Thanks in advance!
  4. GuidoNervi Gingerbread Jun 14, 2019 at 12:53 PM
    GuidoNervi, Jun 14, 2019 at 12:53 PM :
    "Settings->System->developer option->Predefined USB Configuration" set there as "file transfer".
    If you don't see "developer option", you should go in settings->about phone" and tap several times "build number"
    regards
