6
Closed oneplus 6t battery drain
Thread Status:
Not open for further replies.
  1. L1542529546217
    Cupcake Jan 28, 2019
  2. drl431
    Marshmallow Jan 28, 2019
    drl431 , Jan 28, 2019 :
    Battery duration is more up to you, your apps, your app settings, and your phone settings.
  3. mrinalmaiti2008
    Eclair Jan 31, 2019
  4. Gav_W86
    Starting Point Expert Jan 31, 2019
    Gav_W86 , Jan 31, 2019 :
    battery use depends mostly on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots here if you need assistance interpreting.
  5. mrinalmaiti2008
    Eclair Jan 31, 2019
    mrinalmaiti2008 , Jan 31, 2019 :
    brother i know all those things. it's been 3 months that i m using this device. suddenly i am facing this issue . almost like 15/20 dya bck. easily u wll get to know if u r using this this from last 3 months
  6. Gav_W86
    ok, if you know all those things, what do the screens say? pointless asking for advice on a user forum if you are not going to show info.
  7. sabarinathch
    Cupcake Feb 4, 2019
    sabarinathch , Feb 4, 2019 :
    Yes, I am facing the same issue. Please fix the bug. I have tried factory reset. Things were good for one day. Again battery drain has started, reducing my screen on time to nearly half time than usual. Please help. Really annoying.
    Lord Titi likes this.
  8. Gav_W86
    Starting Point Expert Feb 5, 2019
    Gav_W86 , Feb 5, 2019 :
  9. Citizen1448
    Cupcake Feb 14, 2019
    Citizen1448 , Feb 14, 2019 :
    The battery when 1st bought 6t 8gb 256gb was really like "hey this battery just keeps going like am using everything you can throw at it from 7am (100%) till min12pm {25%} I couldn't recommend it any quicker to friends and family.I really pushed one plus to the max. Then after 6 weeks things just seemed slower (much slower) I thought ok I've downloaded my apps etc it's to be expected. then week 8 one plus just becomes a well a little bit above average phone (absolutely gutted). I then proceeded to lose the phone on a night out.(no return) so I bought another similar free £650.00 replacement handset directly off OnePlus.com received said phone and we'll see above for exactly the same time frame and outcome of the (flag ship) phone doing the same slow down and battery drain.
    MY CONCLUSION IS ONE PLUS GIVE YOU SPEEDY GONZALEZ TO START WITH AND COYOTE FLAT FOOT AFTER 8-10 WEEKS. SICK REALLY SICK TO SAY THIS BUT WE ARE BEING BLUFFED BLAGGED AND TAKEN FOR SHEEP.
    MESSAGE TO ONE PLUS IS:
    UP YOUR GAME OR LOSE YOUR LOYAL CUSTOMER BASE VERY QUICKLY.
    THANKS.
    mrinalmaiti2008 likes this.
  10. Gav_W86
    Starting Point Expert Feb 14, 2019
    Gav_W86 , Feb 14, 2019 :
    couple of things:
    -SHOUTING is rude.
    -You are posting on a public community forum of users here, not speaking to OnePlus direct.
    none of this is happening here (or to many others). Seems weird you would spend £650 on another identical phone 8 weeks after buying one that you believe you are having issues with rather than speaking to support, or otherwise seeking help.
    If your battery life is down a lot at the same time you are having speed issues it would possibly say that an app/service is using a lot of processor, power, using battery and possibly causing issues for others.
  11. heysushant
    Donut Feb 14, 2019
    heysushant , Feb 14, 2019 :
    battery life is visibly bad after the recent 9.0.12 update.. has gotten worse after the update of 9.0.11..
    i even wiped my cache.. reset all app preferences.. uninstalled apps.. it makes no difference at all..
    Ps. please don't tell me apps make or break ur battery life.. how i should charge it.. 20 - 80%.. bla bla..
    battery life has visibly gotten worse after the recent updates, period.
    Citizen1448 likes this.
  12. H1546442019183
    Cupcake Feb 16, 2019
    H1546442019183 , Feb 16, 2019 :
    i am using my 6t for around 2 months, first 3-4 weeks the battery was absolutely amazing with a total screen time usage was 8 hours after one full charge to 100%. Atm, it is like 28% remaining of battery with only 4 hours of screen time usage.
    What shall I do
  13. heysushant
    Donut Feb 16, 2019
    heysushant , Feb 16, 2019 :
    i was thinking of a hard reset but i figured that i have wiped my cache, uninstalled almost all apps (to see which one was notorious and the battery app was not able to catch it).. reset all app preferences.. nothing has worked thus far.
    bad support from oneplus. "we listen to the community".. fake.
  14. Citizen1448
    Citizen1448 , Feb 16, 2019 :
    not happening much look around there's posts galore wind ya neck in and JOG ON!
  15. Gav_W86
    Starting Point Expert Feb 17, 2019
    Gav_W86 , Feb 17, 2019 :
    you've still not explain why you would apparently buy a second £650 phone if you were having issues with the first one rather than speaking to support. Doesn't seem normal behaviour.
  16. Citizen1448
    Cupcake Feb 17, 2019
    Citizen1448 , Feb 17, 2019 :
    I don't have to explain anything to you, you wanna be admin!
    Get a life!
  17. Gav_W86
    closing thread that is now just populated by people that don't seem to want assistance.
