14
ONEPLUS 6T Display, Double tap to Wake not working.
  1. G_PRASANTH_GUTTIKONDA_ts
    Eclair Dec 2, 2018
    G_PRASANTH_GUTTIKONDA_ts , Dec 2, 2018 :
    Some times Double tap to Wake not working, phone continues in Sleeping mode ,it is a Bug.In emergency situation to make a call it is a Big problem . please rectify it.
  2. pzeylstra
    Cupcake Dec 2, 2018
    pzeylstra , Dec 2, 2018 :
    Having the same issue
    JelleZon, L_3, K1544463999755 and 4 others like this.
  3. Android450
    Marshmallow Dec 2, 2018
    Android450 , Dec 2, 2018 :
    In an emergency you can quickly press a button. Takes the same amount of time don't be over dramatic
    HK_Axal, JelleZon, SasaX and 4 others like this.
  4. X1543514462746
    Cupcake Dec 2, 2018
  5. ROY RAIMOND
    Eclair Dec 2, 2018
  6. CooL2000
    Cupcake Dec 2, 2018
  7. jimmmysil
    Honeycomb Dec 2, 2018
    jimmmysil , Dec 2, 2018 :
    same here and happens usually after my phone is sitting in my pocket for a long time. When I put it, out double tap is not working, single tap is not working, adaptive display works and I can see the time and my notifications but the fingerprint emblem is white instead of green and placing my finger on the scanner area doesn't unlock the phone. To fix that I have to press the power button once to disable and then again enable my screen. Before the last update I don't had that issue.
  8. alphallama
    Donut Dec 2, 2018
    alphallama , Dec 2, 2018 :
    same issue here it works if the phone has been unlocked recently but if the phones been off a while it doesn't work at all.i have the latest update if this helps to troubleshoot the issue
    K1544463999755 and jimmmysil like this.
  9. cbj4074
    Froyo Dec 2, 2018
    cbj4074 , Dec 2, 2018 :
    I can confirm the same behavior that @jimmmysil describes, and to add to that description, the fingerprint scanner simply will not work at this point until I wake the device with the power button and unlock it with the PIN.
    And to be clear, the ambient display does not say specifically that I need to enter the PIN to unlock it, as it does in other scenarios ("for security reasons"). In this instance, there is no mention of needing to enter the PIN, yet it's required.
  10. MONARCH299
    Eclair Dec 2, 2018
    MONARCH299 , Dec 2, 2018 :
    Its the same with me but I've also noticed that its usually at the top of the screen where its not very active, at least in my case
  11. MONARCH299
    Eclair Dec 2, 2018
    The scanner is very dull and yes it does that sometime with me also
    jimmmysil likes this.
  12. A1541134380649
    Eclair Dec 3, 2018
    A1541134380649 , Dec 3, 2018 :
    Same happened with me too. Had to press power button several times and after few seconds the screen pops up. It is happening every day for once at random time.
    Had this issue after 1st update.
  13. Recoil33
    Cupcake Dec 10, 2018
    Recoil33 , Dec 10, 2018 :
    Issue persists on 9.0.7 as of now. Took my phone out of my pocket after a while (maybe an hour or so) double tap to wake did not work. Had to use the power buttton.
    ROY RAIMOND likes this.
  14. ROY RAIMOND
    Eclair Dec 10, 2018
    Recoil33 likes this.
  15. ngajwani
    ngajwani , Dec 10, 2018 :
    +1 same issue after the most recent update. The screen occasionally gets stuck in pocket mode. Other times it won't come on with a power button press. I have to restart to fix it and disabling pocket mode didn't help.
  16. Q1544330915776
    Q1544330915776 , Dec 10, 2018 :
    Probably need to check if "Tap To Wake" is turned on for the ambient display. If it is you can't have double tap to wake on. It's either one or the other.
    poumpoumk and SasaX like this.
  17. Devendra_Chhajlani
  18. Recoil33
    Guys please like the main thread as well for more visibility. I'm sure more users are experiencing the same problem.
    G_Mark_Dunn_JMmj likes this.
  19. y2k1ltd
    Gingerbread Dec 10, 2018
    y2k1ltd , Dec 10, 2018 :
    Same here, it happens randomly.
    Using Nova Launcher and stock launcher.
  20. AshwinK0
    Honeycomb Dec 10, 2018
