14
ONEPLUS 6T Display, Double tap to Wake not working.
  1. Higira
    Froyo Dec 26, 2018
    Higira , Dec 26, 2018 :
    I'm having same problem. It happens when I don't touch the phone for a couple hours. Pressing the power button wakes it... But what's the point of double tap if I have to touch the power key.. I am on the latest update.
  2. Vamsi Saladi
    Gingerbread Dec 26, 2018
    G_Mark_Dunn_JMmj likes this.
  3. Jashwanth14
    Cupcake Jan 11, 2019
  4. T1537217079498
    Froyo Jan 11, 2019
    T1537217079498 , Jan 11, 2019 :
    When your fingerprint scanner is greyed out and not green, it means it is disabled because of too many failed attempts to unlock is via the fingerprint scanner.
    It seems like you are excidently touching the fingerprint scanner in your pocket.
    jimmmysil likes this.
  5. Higira
    Froyo Jan 13, 2019
    Higira , Jan 13, 2019 :
    no that gray thing happens as well randomly too. it's an android thing. It randomly forces you to use password for god knows why randomly even if you dont touch the finger print. I know this because i had my phone on the table the whole time and came back and it was grayed out. had to type pw in.
  6. DaveGlorie
    Cupcake Jan 23, 2019
  7. ouyamaster
    Honeycomb Jan 23, 2019
    ouyamaster , Jan 23, 2019 :
    I don't remember gestures ever working while phone dialer is open.
    I use exkernel and it always works to tap to wake sleep to sleep to check the time
    When I update to pie I'll see if this is an issue later.
  8. axbog
    axbog , Jan 23, 2019 :
    Same problem. Single or double tap to wake is glitchy. I am starting to get really pissed of with the software and hardware shortcomings of the OP6T.
  9. ouyamaster
    Honeycomb Jan 27, 2019
    ouyamaster , Jan 27, 2019 :
    axbog
    Same problem. Single or double tap to wake is glitchy. I am starting to get really pissed of with the software and hardware shortcomings of the OP6T.​
    Uh have you considered reading up about rooting with exkernel. I am on Pie on Op5T and I can tap to wake and sweep to slleep easily. also sweep left or right to wake or sleep.
  10. axbog
    Honeycomb Jan 30, 2019
    axbog , Jan 30, 2019 :
    I do not want to root just yet. I just need to software to work as it is.
  11. #31
  12. Wingnut24
    Cupcake Mar 28, 2019
    Wingnut24 , Mar 28, 2019 :
    I have the same problem!
  13. thanantonop
    Froyo May 2, 2019
    thanantonop , May 2, 2019 :
    The same problem on my OnePlus 6t . It's a same to have this feature and promote it and some times to work and some other times not
  14. opflarkit
    Cupcake May 5, 2019
    opflarkit , May 5, 2019 :
    Another case where ambient screen works randomly, although "Tap screen to show" is enabled, in Settings->Display->Ambient display
    I prefer to tap the screen, rather than pressing the power button
  15. M1565292578773
    Cupcake Aug 9, 2019
    M1565292578773 , Aug 9, 2019 :
    I am facing the same problem. Sometimes in single tap also the display does not respond and i am not able to see the time screen as well.
  16. Q1548837797725
    Cupcake Oct 16, 2021
    Q1548837797725 , Oct 16, 2021 :
    Why is this crap not working again after a recent update. This is absolutely pathetic. Fix the double tap issue asap. One plus developing into one crap.
  17. Raza_Dawar
    Gingerbread Oct 17, 2021
  18. G_Mark_Dunn_JMmj
    Froyo Oct 27, 2021
    G_Mark_Dunn_JMmj , Oct 27, 2021 :
    I've always had this random problem, it's not something that just started after updating to 11, been troublesome on my phone for several years
    #38
