4
Oneplus 6T display issue
  1. school_30y Donut Dec 2, 2018
    school_30y, Dec 2, 2018 :
    Hello everyone, i just got my OP 6T, and this is my first OP phone. But i find out that on the bottom of the display has an oilish or like light bleeding issue. It occured with or without tempered glass and in view angle just like in the photo. Is this normal? Any thought? Thanks
  2. P@RKER Cupcake Dec 2, 2018
    P@RKER, Dec 2, 2018 :
    this doesn't look normal. looks like damage from pressure like if it was sat on or something. Try to change your background picture to something solid though it might be your picture as well.. hard to tell from the photo quality.
    Ovidiu Ladaru, Sargo and school_30y like this.
  3. felipemendes Jelly Bean Dec 2, 2018
    school_30y likes this.
  4. meatandy Nougat Dec 2, 2018
    meatandy, Dec 2, 2018 :
    Is by chance of pre-applied screen protector peeling off from the edges?
    PearlJam20 and school_30y like this.
  5. samprocat Ice Cream Sandwich Dec 2, 2018
    samprocat, Dec 2, 2018 :
    This definitely is sign of the. users using back pocket and seating on the phone.
    In this scenario you will need full metal case that will be sufficient with your style and have terrible reception.
  6. michaeltrinh Froyo Dec 2, 2018
    michaeltrinh, Dec 2, 2018 :
    I agree, change the wallpaper and see if the issue is still present. If it is, you should submit a ticket/RMA for service.
  7. school_30y Donut Dec 2, 2018
    Well i have checked another OP 6T in local store, and they have the same display as mine. Please check yours guys..
    Panorisi and cruzAD like this.
  8. siny66 Cupcake Dec 2, 2018
  9. xnutzii KitKat Dec 2, 2018
    xnutzii, Dec 2, 2018 :
    Yup, my 6T also has this. Doesn't bother me tho.
  10. YRJ KitKat Dec 2, 2018
    YRJ, Dec 2, 2018 :
    this looks like pressure damage, did you by any chance put it in a back pocket? or put it in a place that would possibly put pressure on the screen?
  11. siny66 Cupcake Dec 2, 2018
    siny66, Dec 2, 2018 :
    I can only speak for myself, haven't had the phone long at all and never put in back pocket or sat on or have any pressure applied to screen so that cannot be the issue.
    cruzAD and school_30y like this.
  12. school_30y Donut Dec 2, 2018
    no, i have never put my phone in my back pocket. As i said above i have checked another 6T in a local store and it has the same issue.
    cruzAD and YRJ like this.
  13. YRJ KitKat Dec 2, 2018
    YRJ, Dec 2, 2018 :
    aha! did you ask the people at store regarding the same?
  14. school_30y Donut Dec 2, 2018
    no i did not, because i assumed that is normal on OP6T
    YRJ likes this.
  15. YRJ KitKat Dec 2, 2018
    YRJ, Dec 2, 2018 :
    how can you make such assumptions? it is clearly a display issue you need to get it rectified at the earliest.
    regards
    Yash [e]1f60a[/e]
    Ovidiu Ladaru likes this.
  16. school_30y Donut Dec 2, 2018
    yes maybe you are right, but as you can see above some of the owners of 6T they also have the same problem. And also if i look my phone in normal view (parralel with my eyes) then this issue wont appeared.
  17. school_30y Donut Dec 2, 2018
    oo okay. so we can assumed that is normal on 6T right?
  18. YRJ KitKat Dec 2, 2018
    YRJ, Dec 2, 2018 :
    If you feel that this is normal. then what is the problem?
    enjoy you device!
    Ovidiu Ladaru and school_30y like this.
  19. school_30y Donut Dec 2, 2018
    thanks, so can we assumed that is normal on 6T then?
  20. NowayKiller02 Cupcake Dec 2, 2018
    NowayKiller02, Dec 2, 2018 :
    i have the same issue
