4
Oneplus 6T display issue
  1. W1546518040516 Cupcake Jan 10, 2019
    W1546518040516, Jan 10, 2019 :
    I have the same effect, but not as severe as you though. Tried changing it to different solid colored backgrounds, only appears on bright colored ones
    #61
  2. P1546783369507 Donut Jan 10, 2019
    P1546783369507, Jan 10, 2019 :
    try to check with White wallpaper and with full brightness
    #62
  3. LCollinsJr82 Gingerbread Jan 10, 2019
    LCollinsJr82, Jan 10, 2019 :
    I have, no issues. Screen is perfect.
    #63
  4. P1546783369507 Donut Jan 10, 2019
    im Happy for you, but It isnt easy to notice this issue, infact i noticed it After a lot of time of checking It, and also this effect didnt affect normal usage, i think Is a polarisation effect :)
    #64
  5. Jesús_Ramírez Cupcake Jan 10, 2019
    Jesús_Ramírez, Jan 10, 2019 :
    what is not normal is that all of them dont have that "issue"...
    #65
  6. P1546783369507 Donut Jan 10, 2019
    i think they didnt notice It, when you see this effect the first time , than you are able to see again and with other device, for me it isnt easily to see the effect for the first time
    #66
  7. Jesús_Ramírez Cupcake Jan 10, 2019
    P1546783369507
    It's impossible they didnt see it and know it... I saw it at moment I know it...
    #67
  8. felipemendes Jelly Bean Jan 10, 2019
    felipemendes, Jan 10, 2019 :
    I said on a very early post that I didn't have this problem, but I do. Is visible with white images from very sharp angles from the screen. Other than that, is invisible.
    #68
  9. P1546783369507 Donut Jan 10, 2019
    my same situation
    #69
  10. school_30y Donut Jan 10, 2019
    school_30y, Jan 10, 2019 :
    maybe there is connection between this issues with finger gestures, because they all in the same spot
    #70
  11. LCollinsJr82 Gingerbread Jan 10, 2019
    I've put up a white background, even used the OnePlus forum app which is white as well, full brightness and looking at it from every possible angle and I don't have this issue.
    It's not on every phone. It could be a manufacturing issue or it falls within the acceptable limits. Has anybody contacted OnePlus with this issue?
    We are such a small sample size and typically only those with issues will speak up. This could be an issue that affects just a small percentage of users, but because only those with issues speak up, it makes the problem look more wide spread than it is.
    #71
  12. X1547132995511 Cupcake Jan 10, 2019
    X1547132995511, Jan 10, 2019 :
    i too have this issue. i just bought this phone from amazon india. i can see the green light. i am not sure if this creates a problem
    #72
  13. Jesús_Ramírez Cupcake Jan 10, 2019
    I think so. It's the first thing I thought... Gestures, plastic protector, dirt, ...
    #73
  14. felipemendes Jelly Bean Jan 10, 2019
    A dark environment "helps" too. Even then this is barely visible. It seems more of an internal reflex than a stain coming from the screen, as it seems to change with the angle.
    #74
  15. Leoncino95 Froyo Jan 10, 2019
    Leoncino95, Jan 10, 2019 :
    does somebody feel like a static electricity while charging the phone without the case?
    #75
  16. LCollinsJr82 Gingerbread Jan 10, 2019
    Again, there is no issue with my display. I have checked it repeatedly. When I first came across this thread I was in bed about to go to sleep, so obviously the lights were off. Someone has even posted pics of their display with no issues, but you guys seem to be ignoring that post.
    This seems to be very difficult for some of you to grasp, but this issue does not affect all phones. Instead of trying to prove that all phones have this issue, when they don't, why not just contact OnePlus and see what they say. Then report back to this post with what their response was. I have a feeling that there is a tolerance to these screens and if they are within a specified window, they are considered good.
    #76
  17. LCollinsJr82 Gingerbread Jan 10, 2019
    #77
  18. felipemendes Jelly Bean Jan 10, 2019
    Mine has it, but honestly I consider it good. I'm not ignoring your post, but since I said first that I didn't have it, then I saw it, I'm trying to give more detail to find it, if exists, and if you're curious. And if yours don't have it, congratulations, I guess. One less thing to worry about (or not. I don't).
    It may even be diffraction between the light emitting surface and the glass. Again, I wouldn't worry.
    #78
  19. W1546518040516 Cupcake Jan 10, 2019
    Has anyone got in contact with oneplus? I'd do it, but it's kinda hard for me cuz there are no official stores in my country
    #79
  20. inigosh Froyo Jan 12, 2019
    inigosh, Jan 12, 2019 :
    RexxonHD
    I had the same problem until I took my plastic screen protector off. If u want to fix this buy a glass protector.​
    Nope. I have removed the screen protector and the issue stays there.
    #80
