2
OnePlus 6t fingerprint sensor not working
  1. SirConius
    Donut Nov 12, 2018
    SirConius , Nov 12, 2018 :
    after a week of always working, out of the blue my phone stopped recognizing my fingerprint. Added and readded my fingers and thumb. restarted my phone nothing is working.
    Does anyone have an idea how to fix this
    Possible update? Nu screen doesn't go light up when I use the scanner (it previously did) I didn't change any settings. Even reset my phone still not working.
    Ok I can get it to work but only if I use the ambient display. It takes 3 or 4 tries and then it unlocks... @OnePlus please fix this
    tomas101 and girishb86 like this.
  2. dickymastelero
    Eclair Nov 12, 2018
    dickymastelero , Nov 12, 2018 :
    If you have recent system updates the try rebooting and redo fingerprints. If you just put a aftermarket tempered glass screen then it might have compromise sensor.
  3. SirConius
    Donut Nov 12, 2018
    I still have the official screenprotector from OnePlus on it. Had a system update a fee days ago and then it gave me no problem.
  4. dickymastelero
    Eclair Nov 12, 2018
  5. SirConius
    Donut Nov 12, 2018
  6. dickymastelero
    Eclair Nov 12, 2018
    Mine is perfectly fine but there is still a hit and miss sometimes, new technology under the screen maybe humidity plays a factor too. Anyways phone is 100 percent, I find turning on face unlocking is better and way faster when access to phone. Support will probably get back on you and hope all is well.
  7. SirConius
    Donut Nov 12, 2018
    I hope so. For now I did enable face unlock. Still a bit sad, the fingerprint scanner under the screen is so cool. But we'll have to wait for an update I guess
  8. dickymastelero
    Eclair Nov 12, 2018
  9. SirConius
    Donut Nov 13, 2018
    SirConius , Nov 13, 2018 :
    I am on the latest update for the system and security. even checked if there was an update
  10. SteveDaniel1975
    Donut Nov 14, 2018
  11. sypherd1
    Donut Nov 14, 2018
    sypherd1 , Nov 14, 2018 :
    Sept 5th is as new as it is if you are on Tmo
    SteveDaniel1975 likes this.
  12. dickymastelero
    Eclair Nov 14, 2018
    dickymastelero , Nov 14, 2018 :
    November 1 according to my update, you can manually do it if you have too.
  13. G_Claudiu_Lucian_SkeQ
    Cupcake Nov 14, 2018
  14. mkgaggar
  15. mkgaggar
    mkgaggar , Nov 14, 2018 :
    face unlock disable krne k Baad to fingerprint sensor work hi nahi kr Raha...what to do
    harithadasagari likes this.
  16. Vamsi Saladi
    Gingerbread Nov 16, 2018
    Vamsi Saladi , Nov 16, 2018 :
    There was a fingerprint guide by Oneplus i read some time back. they said if you are facing issue with reading. Try removing all the registered prints. Reboot. Re-Register the prints in complete darkness. And finger print registration has 2 parts.
    part-1: different angles of centre area
    part-2: edge reading
    so place finger appropriately as per the parts
    m1ster0wl likes this.
  17. SirConius
    Donut Nov 16, 2018
    SirConius , Nov 16, 2018 :
    I'm sorry what
  18. Vamsi Saladi
    Gingerbread Nov 17, 2018
    Vamsi Saladi , Nov 17, 2018 :
    Restart to recovery mode by pressing power +volume down key
    Clear cache.
    Try re adding fingerprints by deleting existing.
    Mine fingerprint was working even without face unlock disabled
    dickymastelero likes this.
  19. G_Claudiu_Lucian_SkeQ
    Cupcake Nov 17, 2018
    G_Claudiu_Lucian_SkeQ , Nov 17, 2018 :
    Hey guys, i found a fix for this. I tried clearing the cache from recovery mode, even factory reset, but those didn't help.
    A sure fix for this (i tried it two times and it worked) is running a fingerprint calibration test. Enter engineer mode (dial *#808#), do the calibration test and it fixes itself. You don't need to delete the fingerprints, it works with the old ones.
    J@couille likes this.
  20. M1542977306308
    Cupcake Nov 23, 2018
    M1542977306308 , Nov 23, 2018 :
    when i did the calibration test i got this error. anyone knows what to do?
    alecjw87 and J@couille like this.
