95
OnePlus 6T Original Case Questionnaire
  1. YRJ
    The Lab - OnePlus 7T Reviewer Dec 22, 2018
    YRJ , Dec 22, 2018 :
    the case really does not offer heavy protection,against impacts and drops.
    it is a good thing to have though! and put on as soon as the phone is unboxed and while the user buys a case of his choice!
    The best part is that it fits exceptionally well! but still it need to be worked on.
    cheers!
    Shiz Strada and VincentAbee like this.
  2. gokul_m_pillai
    Cupcake Dec 22, 2018
    gokul_m_pillai , Dec 22, 2018 :
    In my case the elevated corners didn't do much, one slip from pocket damaged the bottom right corner of screen i.e. exactly at the corner and resulted a full screen replacement of 171$.
  3. gokul_m_pillai
    it's just a cover with neat design nothing much to offer , In my case the elevated corners didn't do much, one slip from pocket damaged the bottom right corner of screen i.e. exactly at the corner and resulted a full screen replacement of 171$.
  4. goforjoshua
    Donut Dec 22, 2018
    goforjoshua , Dec 22, 2018 :
    The original 6T case is okay and all; I used the one that came with my 5T. But I opted for the Nylon bumper case this time around, which is fantastic. If anything happens to that one I won't have a problem using it as a backup.
  5. Vignesh_chandz
    Honeycomb Dec 22, 2018
    Vignesh_chandz , Dec 22, 2018 :
    gave my feedback regarding the case. it's really so nice soft OnePlus to add a case but it actually feels so light. I really doubt the protection it assures to my phone when fallen down aside from scratches.
  6. Tudor2308
    Gingerbread Dec 22, 2018
    Tudor2308 , Dec 22, 2018 :
    Hi I see all of here are praising the case and I totally understand why but we are here to improve it if possible, so my complaints is about how much it's coming over the screen, I use gestures and usually is so uncomfortable that I prefer to use it without case, on my 5t this wasn't a issues, yes it's looking to be more protective but also it's more annoying for someone who use OnePlus gestures
  7. Tudor2308
    I don't think that scrabbing your fingers on the case every time when you use gestures it's normally, otherwise top quality, a very good, well designed case
    C1539513717008 likes this.
  8. Agneya123
    MarvelousMe likes this.
  9. G_Mohamed_Ibrahim_sHZG
    MarvelousMe and ldwp27 like this.
  10. sanjay_297
    Donut Dec 22, 2018
    sanjay_297 , Dec 22, 2018 :
    I'm still using it with my OnePlus 6T without going for any other cases in the market. I think u got ur answer OnePlus.....
  11. Ambatti
    Eclair Dec 22, 2018
    Ambatti , Dec 22, 2018 :
    Good move by OP team. Things should refine and improvement and quality upgradation should happen simultaneously. Scope to improve the quality is to happen for up coming models.
  12. Nickel Nitro
    Froyo Dec 22, 2018
  13. Nickel Nitro
    Froyo Dec 22, 2018
  14. U1544927838287
    Donut Dec 22, 2018
    U1544927838287 , Dec 22, 2018 :
    I don't see warranty paper along with the box...so do I need to visit one plus store for it or receipt of online seller will be considered a beginning of warranty
  15. gwen2206
    gwen2206 , Dec 22, 2018 :
    the original is ok, but for me the camera cut out was too big, making me touch the camera frequently. and of course with the thunder purple a completely clear case makes more sense to me
    vadember, Lumarie and Rocket Man like this.
  16. Lumarie
    Eclair Dec 22, 2018
    Lumarie , Dec 22, 2018 :
    I really like the original case but in my case I am a woman and I have the One plus 6t thunder purple and I think that although it is a very good case you are not thinking about the female audience I would like more female cases and not all so masculine, in my case I am using my One plus 6t with an eBay flower cases.
    gwen2206 likes this.
  17. Nadeem.Sarhan
  18. R1545493337053
    R1545493337053 , Dec 22, 2018 :
    a protective case with new phone saves a lot of time , and you are worry Free. the case protect all the edges nicely. it does that it suppose to do. thanks one plus for the coase and pre install screen protector.
    #38
    Lumarie likes this.
  19. nikhilnbhosale89
    #39
  20. Anthony Heaven
    Eclair Dec 22, 2018
    Anthony Heaven , Dec 22, 2018 :
    the original case that had come with the Oneplus 6T was something I had not expected ; for the presentation I thought it would of been a flimsy cheapish case. How I was wrong , it feels really good in the hands , it is not easy to bend and the buttons are really responsive the four corners with the raised corners is a good touch to add very different to other cases to come with a phone ; colour wise it is a very stealthy case that complements the phone itself. I have used other cases but I often return to the case it had come with but it does feel like it is missing something on the protective side but I have yet to spot it. although I know it is just a little case to protect the phone. But so far I believe it is great.
    #40
    Rocket Man likes this.
