2
Oneplus 6T PC connect usb not recognised
  1. Jagadeeshanram Cupcake Feb 16, 2019
    Jagadeeshanram, Feb 16, 2019 :
    When i connected my OnePlus 6t phone to windows 10 pc it was showing usb device connected is not recognised. I tried in all possible ports, I changed cable and tried but no luck.
    I turned on the developer options and enabled usb debugging after that i could able to connect the one plus 6t to windows 10 pc.
    Once again when I turned off the developer options off same problem occurs. I could able to connect mobile to pc only when usb debugging options enabled.
  2. freakazoid67216 Donut Feb 16, 2019
    freakazoid67216, Feb 16, 2019 :
    I would personally say that this is a more common thing that I have come across with a lot of android devices. I have owned LG, Samsung, Motorola, Sony, HTC, and now the One Plus and have always had to turn developer options on to allow for data transfer from device to PC via any windows OS.
  3. Jagadeeshanram Cupcake Feb 16, 2019
    Even for simple file transfer why we need to enable developer option usb debugging. USB debugging was intended to connect mobile to pc for any development work.
    For a normal mobile user simply it should connect.
    I also used Samsung, Moto i never faced this issue.
    usually it will be connected as charging, we need to change the mode of connectivity only.
    this seems to be OnePlus device bug
    Q1552604118239 likes this.
  4. Neddard KitKat Feb 16, 2019
    Neddard, Feb 16, 2019 :
    No problems at all connecting my 6T to both Win8.1 and Win10 laptops and being recognized. No special settings required. No USB debugging mode required.
  5. Manyeko Sharingan Eclair Feb 17, 2019
  6. LegolasX Ice Cream Sandwich Feb 17, 2019
    LegolasX, Feb 17, 2019 :
    you need to remove the driver and reinstall it.
    usb debugging is not required for normal file transfer or charging.
    also install OnePlus drivers available in your phone.
  7. Q1552604118239 Cupcake Mar 16, 2019 at 1:16 AM
    Q1552604118239, Mar 16, 2019 at 1:16 AM :
    My op6 can not be recognized by my laptop at all and I have tried everything in these forums and what little info there is on the net to no avail finally had to install a third party app to use wifi to transfer files! What a letdown this phone has become. Going from a Galaxy S7 to the OP6 was like taking a step backwards, never had issues like this with Samsung!
    G_Sarwat_Khan_hSwX likes this.
