6
oneplus 6t screen protector
  1. Saravanan saru
    Froyo Dec 8, 2018
    Saravanan saru , Dec 8, 2018 :
    worst quality of screen protector from oneplus,I loosing quality confidence from OnePlus ,I bought last week 3d screen protector from OnePlus website , it's fit to the screen correct but the screen get worst mark came after to three day & three dot appeared on bottom of d screen it not bubble mark ,is there any replacement ,I'm worried abt my screen ,its two much for screen protector 999₹ waste of money
  2. Z1539275796863
    Donut Dec 8, 2018
    Z1539275796863 , Dec 8, 2018 :
    same thing happened to me also. I bought two screen protectors from oneplus and faced issues in both products. Worst thing is they won't refund your money. bcos it is Never Settle!!
  3. vijay_lalwani
    Honeycomb Dec 8, 2018
  4. Saravanan saru
    Froyo Dec 8, 2018
    never settle [e]1f602[/e]
  5. Vamsi Saladi
    Gingerbread Dec 8, 2018
    Vamsi Saladi , Dec 8, 2018 :
    Yours is much better, mine got 2 slits near both side bottom side bezzels.
    And i feel the protector thicker and not comfortable, I re-registers finger prints but finding some latency and non detection after installation
  6. Saravanan saru
    Froyo Dec 8, 2018
    from local I bought two screen protector 9 guard crach proof but the OnePlus item nothing good compare to that item ,only d screen fit correct
    X1517396854503 and Vamsi Saladi like this.
  7. ®akesh
    Eclair Dec 9, 2018
    ®akesh , Dec 9, 2018 :
    same happened with me.
    I put all my effort to stick the offcial screen guard to OP6T.
    still bubbles on corner's.
    you can go for Nillkin brand . it's amazing.
  8. Saravanan saru
    Froyo Dec 9, 2018
    Saravanan saru , Dec 9, 2018 :
    wt abt d screen fit is it good in nikil
  9. ®akesh
    Eclair Dec 9, 2018
    yes. That does not have black borderline in screen guard.
    I have been using this brand since 2015 for all my phone's.
    perfect fit.
    you can find it in amazon.in or directly free shipping from https://nillkin.org website from China. it took 2 weeks for me to reach from China.
  10. 2pints
    Ice Cream Sandwich Dec 9, 2018
    2pints , Dec 9, 2018 :
    I'm having the same issues with bubbles appearing at the sides
  11. Naughty_Potato
    Gingerbread Dec 10, 2018
    Naughty_Potato , Dec 10, 2018 :
    i had to buy it twice. After miserably failing for the first time after hours of effort, I threw it away. Then I bought it again and went to OnePlus store and asked it's executive to apply it for me. Still there are two bubbles. There were 4 but I kept my phone under constant pressure for two nights using books. Now it's two. Absolutely worst quality tempered glass.
    Moreover it cuts into screen space but to lines also. Outrageous.
    Vamsi Saladi likes this.
  12. Naughty_Potato
    The OnePlus executive also told that they have sent back the batches of screen protector coz they are defective.
  13. Saravanan saru
    Froyo Dec 10, 2018
    Saravanan saru , Dec 10, 2018 :
    Naughty_Potato
    The OnePlus executive also told that they have sent back the batches of screen protector coz they are defective.​
    wt abt d money we spend on d screen protector not worthy for us
    Naughty_Potato likes this.
  14. Naughty_Potato
  15. Naughty_Potato
    I think they should refund it.... There should be an option while buying the phone whether there should be a company fitted tempered glass or not.
  16. Naughty_Potato
    First time I was dejected... Thought it was my fault. This is bad faith. Introducing defective accessories.
    whatdatinvitedo likes this.
  17. AmanRaj7
    Donut Dec 10, 2018
    AmanRaj7 , Dec 10, 2018 :
    And here i thought, it was my mistake in applying them. Wasted 2 hrs still have bubbles at the bottom
  18. vijay_lalwani
    Honeycomb Dec 10, 2018
    vijay_lalwani , Dec 10, 2018 :
    I used clips at the areas where bubbles were persistent. you should try that.
  19. Naughty_Potato
    Did the bubbles reappear after removing clips?
  20. simon6
    Cupcake Dec 10, 2018
