OnePlus 6T WiFi Calling Issues
  1. JPHebert
    Cupcake Aug 8, 2020
    JPHebert , Aug 8, 2020 :
    Hi folks!
    I read forums and alas, no luck, I went into the LogKit with *#800# and do not have the option to turn this function on for some reason. No WiFi calling whatsoever. Sad Panda.
    Here is my info:
    • OnePlus 6T model A6013
    • Latest OxygenOS on Android 10 (10.3.5) from from this morning
    • Am in Canada on the Telus network
    • I have commercial-grade WiFi at home :p
    Any suggestions?
    Thanks!
  2. rhyd1am
    Jelly Bean Aug 8, 2020
    rhyd1am , via OnePlus 6T , Aug 8, 2020 :
    It took me a long time to find a solution to this when android 10 first arrived (I had the same problem myself).
    I ended up being able to get it back by downloading an older version of OnePlus engineer mode from APK mirror. As you can see from the first screenshot, the options are available on my 6t
    The second screenshot is the version of Engineer mode that I have installed on my device.
    Caomhin likes this.
  3. JPHebert
    Cupcake Aug 10, 2020
    JPHebert , Aug 10, 2020 :
    Thanks! For some reason with the APK you told me to install I still can't see the options. Bummer. Thoughts?
