21
OnePlus 7 - Adaptive Brightness Problem
  1. N1520431260526
    Froyo Jun 19, 2019
    N1520431260526 , Jun 19, 2019 :
    The Adaptive Brightness feature on my OnePlus 7 device doesn't work smoothly. It takes a good amount of time to adjust based on the light around. I had OnePlus 5t earlier , Adaptive Brightness worked really well , but in OnePlus 7 it's not that responsive, it takes Longer than usual to adjust. Has anyone else faced this problem? please comment.
  2. G_shuvs_roy_shuvs_roy_bd
    Froyo Jun 20, 2019
    N1520431260526 likes this.
  3. mudassarrauf
    Froyo Jun 21, 2019
  4. ravi4ur2001
    Donut Jun 21, 2019
    ravi4ur2001 , Jun 21, 2019 :
    i am also facing the same issue either Adaptive Brightness is not responding or works too slow. also its not adjusting to correct level.
    shyamksr and N1520431260526 like this.
  5. ravi4ur2001
    Donut Jun 21, 2019
    no its not good enough outside you have to make some effort to look at screen
  6. vgupta1192
    Gingerbread Jun 21, 2019
  7. Deactivated User
    Jun 21, 2019
  8. N1520431260526
    Froyo Jun 22, 2019
    N1520431260526 , Jun 22, 2019 :
    I think it's a little less bright out in open even on full Brightness level.
  9. Gautam vaish
    Cupcake Jun 23, 2019
    Gautam vaish , Jun 23, 2019 :
    I am also facing same issue, Auto Brightness is not working properly or sometimes works slow...
  10. N1520431260526
    Froyo Jun 23, 2019
    N1520431260526 , Jun 23, 2019 :
    Report it in OnePlus feedback forum also.
  11. shyamksr
    Donut Jun 24, 2019
  12. Mikeyboy80
    Eclair Jun 25, 2019
    Mikeyboy80 , Jun 25, 2019 :
    Yeah think i have the same issue. I had the phone in Night mode and im sure when I woke up the device in the morning, it changed from the'day/normal' mode back to the yellow tint night mode which is should have been on anyway? It was like the autobrightness randomly changed.
  13. irfanmoosani
    KitKat Jun 25, 2019
    irfanmoosani , Jun 25, 2019 :
    Yes, same issue. Even setting full brightness does not produce enough brightness for screen to view it in outdoors in sunlight
  14. n0k5
    Cupcake Jun 25, 2019
  15. ravi4ur2001
    Donut Jun 26, 2019
  16. G_shuvs_roy_shuvs_roy_bd
    Froyo Jun 27, 2019
    G_shuvs_roy_shuvs_roy_bd , Jun 27, 2019 :
    please report it to fix the probelm.
    irfanmoosani likes this.
  17. irfanmoosani
    KitKat Jun 27, 2019
    irfanmoosani , Jun 27, 2019 :
    Aren't we reporting over here?
  18. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 27, 2019
    Dresa91 , Jun 27, 2019 :
    1) NO, because this is an USER FORUM and not a support page. Your are an Ice Cream Sandwich. You should know that here are NO DEVS or support people of OnePlus!
    2) to all:
    the adaptive brightness is working different with Android 9 compared to 8.
    There is an AI, which is learning from your behavior. It is implemented by Google!
    Please use search function before creating redundant threads!
  19. N1520431260526
    Froyo Jun 27, 2019
    N1520431260526 , Jun 27, 2019 :
    Dresa91
    1) NO, because this is an USER FORUM and not a support page. Your are an Ice Cream Sandwich. You have to know that here are NO DEVS or support people of OnePlus!
    2) to all:
    Please use search function before creating redundant threads!​
    Then I would say Adaptive Brightness on Android 8 was better than Android 9. It was very responsive and accurate. So may be the AI part of Adaptive Brightness feature in OnePlus7 not working properly, because it does not adjust properly, takes a lot of time, and sometimes even after reducing the brightness manually, it takes more time to actually reflect that on screen. This is a general support forum for onePlus 7, that's why I have put it here.
    I have also raised this issue in the feedback forum
  20. Dresa91
    wrong: this is an USER FORUM!
    not a support forum!
    here are users like you and me!
    you have to train the AI....please use Google and read something about it. It helps you.
