3
oneplus 7 ambient light sensor and proximity sensor
  1. Advaith_Pawar
    Cupcake Aug 1, 2019
    Advaith_Pawar , Aug 1, 2019 :
    Does anyone know where all the sensors for the oneplus 7 are?? Because there is no pocket mode for oneplus 7 now which uses proximity sensor.
  2. zvczv
    Froyo Aug 4, 2019
    zvczv , Aug 4, 2019 :
    Don't know where exactly, but they're there. When having a call or listening to a voice note on WhatsApp, the proximity sensor works fine. It's just the pocket mode that has gone from oos apparently.
    Advaith_Pawar likes this.
  3. Starcommander
    Lollipop Aug 4, 2019
    Starcommander , Aug 4, 2019 :
    It uses a software based proximity sensor where the ear piece speaker emits a high frequency sound and when any object comes near the phone especially while call, the reflected high frequency noise is captured by the the secondary microphone to judge the distance. It's called elliptic labs virtual sensor.
  4. Advaith_Pawar
    Cupcake Aug 4, 2019
    Advaith_Pawar , Aug 4, 2019 :
    Hey, thanks for info about the proximity sensor, but what about the light sensor?? The auto brightness feature isn't working that well. I have to adjust the brightness manually most of the time.
    Starcommander likes this.
  5. Starcommander
    It uses machine learning. It will learn your pattern and then adjust automatically
  6. Advaith_Pawar
    Cupcake Aug 4, 2019
    Woah. That's something Thanks for letting me know. Hope it will get better with time.
  7. Starcommander
    Yup it will
  8. puneeth_choppanati
    Eclair Aug 10, 2019
    puneeth_choppanati , Aug 10, 2019 :
    even after the latest update, ambient light sensor is not precise. I tried it in a pitch dark room and it was still emitting some bright light off the screen. and the calibration is also kind of slow. I really wish OnePlus would consider this seriously and improve even more.
  9. Paulo Viana
    Froyo Aug 15, 2019
    Paulo Viana , Aug 15, 2019 :
    Tenho problemas ao reproduzir notas de áudio por meio do WhatsApp, sempre que o áudio é pausado ou movido para cima I have problems playing audio notes through WhatsApp, all the time the audio is paused or transferred to the internal speaker, as if it had approached the ear, this is frustrating
  10. Nateshvicky
    Eclair Sep 16, 2019
    Nateshvicky , Sep 16, 2019 :
    me too facing. the same ...light sensor is little bit slow and sometimes after the call , the phone doesn't lights up ..
  11. bkavinoff
    Eclair Sep 16, 2019
    bkavinoff , Sep 16, 2019 :
    I have the same problem when I'm listening to Whatsapp Audios...
    Paulo Viana likes this.
  12. Paulo Viana
    Froyo Sep 17, 2019
  13. Paulo Viana
    Froyo Sep 17, 2019
  14. cifp48
    Cupcake Sep 25, 2019
  15. Paulo Viana
    Froyo Sep 25, 2019
    Paulo Viana , Sep 25, 2019 :
    [QUOTE = "cifp48, post: 20798118, membro: 1988076"] alguma atualização sobre isso? Também estou com esse problema [/ QUOTE]
    it's frustrating the manufacturer doesn't respond
  16. Cervantes
    Lollipop Moderator Sep 25, 2019
    Cervantes , Sep 25, 2019 :
    Hi
    You are kidnapping is thread
    This thread is about light sensor and proximity sensor
    The One Plus forum is multilanguage, but you must write in the first post language:
    the threads must be only in one language
    You have a bug reporting forum
    bkavinoff likes this.
  17. Paulo Viana
    Froyo Sep 25, 2019
    [QUOTE = "Cervantes, post: 20798330, membro: 76118"] Olá
    Você está sequestrando é fio
    Este tópico trata do sensor de luz e sensor de proximidade
    O fórum do One Plus é multilíngüe, mas você deve escrever no primeiro idioma da postagem:
    os encadeamentos devem estar apenas em um idioma
    Você tem um fórum de relatórios de erros
    Você pode usar o mecanismo de pesquisa antes de abrir um novo tópico
    Obrigado, Cervantes, Moderador do fórum [/ QUOTE]
    no use, never the manufacturer will solve, money thrown away
  18. Cervantes
    Lollipop Moderator Sep 26, 2019
    Cervantes , Sep 26, 2019 :
    You can raise your problem in the Portuguese language forum
  19. Q1569877153665
    Cupcake Nov 1, 2019
    Q1569877153665 , Nov 1, 2019 :
    same issue here.. the light sensor has mind of its own.. it work sometimes.. and sometimes not.. while typing text it all goes dark.. not sure where the fault is...
