15
Oneplus 7 camera
  1. bradleycooper Donut Jun 17, 2019
    #81
  2. fbocplr Cupcake Jun 17, 2019
    fbocplr, Jun 17, 2019 :
    If you guys take a photo in the built-in camera app from instagram (or Snapchat, WhatsApp,...) does your image also have a lot of noise?
    #82
    H1560664183653 likes this.
  3. bradleycooper Donut Jun 17, 2019
    #83
  4. bradleycooper Donut Jun 17, 2019
    #84
  5. fbocplr Cupcake Jun 17, 2019
    or in general every app that uses the camera except the stock camera app.
    #85
  6. The_Spark Eclair Jun 17, 2019
    The_Spark, Jun 17, 2019 :
    The Pro version.
    #86
  7. TarveshChauhan Eclair Jun 18, 2019
    TarveshChauhan, Jun 18, 2019 :
    bogus
    #87
  8. fbocplr Cupcake Jun 18, 2019
    #88
  9. Ashish_K_Singh Eclair Jun 18, 2019
    Ashish_K_Singh, Jun 18, 2019 :
    Check this out.... Just tried to click some portrait mode shots & getting these results... Even after updates 9.5.5 this is the output of OnePlus7. Really very disappointed...
    #89
  10. fbocplr Cupcake Jun 18, 2019
    fbocplr, Jun 18, 2019 :
    Portrait is not for landscapes...
    #90
  11. bradleycooper Donut Jun 18, 2019
    bradleycooper, Jun 18, 2019 :
    Shame- I can see the blurry part half way up the tree
    #91
    Ashish_K_Singh likes this.
  12. bradleycooper Donut Jun 18, 2019
    Do you mean Portrait as in the phones orientation or using portrait mode in the camera settings?
    #92
  13. Ashish_K_Singh Eclair Jun 18, 2019
    Thanks for ur suggestions... but this was not in landscape, the orientation was in correct angle.. [e]1f60a[/e]
    #93
  14. fbocplr Cupcake Jun 18, 2019
    no, you don't understand me, the portrait mode is just for close subjekt. not for trees that are far away
    #94
  15. Ashish_K_Singh Eclair Jun 18, 2019
    Bro it was not so far... & plz don't mistake me as i m also a big fan of OnePlus and I can differentiate easily because these problems was not there on my previous device OnePlus 6T. Trust me there r so many issues with this OnePlus7 which was not on 6 or 6T. It seems like this time company putting there whole efforts on 7 Pro only...
    #95
  16. fbocplr Cupcake Jun 18, 2019
    the camera software on the op7 is the same as the one on the op7 pro and the Portrait mode can't logically work on objects further away than around 1m because there can't be depth of field. Trust me on that.
    But in notice some quirks as well, like my camera quality in third party apps is really bad. But my guess is that the new IMX586 sensor is not supported from these apps until now.
    #96
  17. fbocplr Cupcake Jun 18, 2019
    and by the way a tree is probably the most difficult objekt to use the portrait mode on, because it has no defined edges.
    #97
  18. Ashish_K_Singh Eclair Jun 18, 2019
    it means definitely some problems on the other brands phone through which people are getting very good effects of portrait pics even for also...
    #98
  19. TarveshChauhan Eclair Jun 19, 2019
    TarveshChauhan, Jun 19, 2019 :
    artificial image quality
    #99
  20. Rishabh_Agrawal_1Plus Eclair Jun 19, 2019
    Rishabh_Agrawal_1Plus, Jun 19, 2019 :
    Update improves camera performance but still not satisfactory
    --> Auto focussing is still much slower then poco f1 which i was using recently
    -->photos clicked with oneplus 7 are not sharp (in wide shots like architectural)
    -->48 megapixel mode colours are washed out
    -->saturation level is also a bit off as compared to oneplus 6t
    -->features like photo sphere can be added which we find in google camera to minimise the lack of ultra wide angle camera in oneplus 7 and older devices
    -->it would be better if night Scape use camera flash to further illuminate the scene
    -->pictures are grainy
    -->Pictures taken in nightscape is pixelated when zoomed a little . when i compared it to gcam night vision I found a huge difference
    ---->CAMERA NEEDS A MAJOR UPDATE SPECIALLY FOR AUTOFOCUSING AND SHARPNESS
    --> Audio latency still there while playing audio through bluetooth headphones
    -->gradually increase volume option is missing for caller ringtones (which was there in miui)
    -->recent apps animation can be smoother
    -->there must be an option for disabling recently deleted folder in gallery app
    --> Recognition of registered finger print becomes slow after some day (Is there anyone else who has faced such issues)
    ONEPLUS IF YOU ARE SEEING THIS PLEASE FIX THIS ASAP
    YOU LAUNCHED TWO SMARTPHONE THIS YEAR NOT ONE
    GIVE SOME ATTENTION TO ONEPLUS 7 TOO
