Oneplus 7 display issue
  1. ganto007
    Cupcake Jun 29, 2019
    ganto007 , Jun 29, 2019 :
    help me clarifying the oneplus 7 display issue.
    when i get move my brightness between 25-40%, i can see a worm like shadow which starting from top right corner to middle right. i dont see this thing as normal one. i have referred the issue with another friend's oneplus 7. he is not having this issue. i have cleared cache memory. not helping though. pls help me guys. pls
    Shubhraj Sehgal likes this.
  2. Shubhraj Sehgal
    Donut Jun 29, 2019
    Shubhraj Sehgal , Jun 29, 2019 :
    I also have this issue at the same spot top right to middle right.
    Is it covered in warranty?
    Its a display quality issue most probably
    One the flipside it can also be a copper heatsink like in gaming phones
    ganto007 likes this.
  3. ganto007
    I don't know bro. may be they can correct it via any update!!!
  4. Shubhraj Sehgal
    Donut Jun 29, 2019
    Its a hardware issue bro no software can help
  5. ganto007
  6. ganto007
  7. Shubhraj Sehgal
    Donut Jul 1, 2019
  8. ganto007
    Cupcake Jul 9, 2019
  9. Shubhraj Sehgal
    Donut Jul 9, 2019
    Shubhraj Sehgal , Jul 9, 2019 :
    i went to the service centre and they denied any repair or replacement as issue wasnt visible on normal 50 60% brightness and "any issue at low brightness is not their fault"
    MORONS
  10. avik331
    Froyo Jul 9, 2019
    avik331 , Jul 9, 2019 :
    call their customer care and talk to them. they are more helpful than the service centre guys
  11. N1563011274517
    Cupcake Jul 13, 2019
    N1563011274517 , Jul 13, 2019 :
    I am using one plus 7 I brought it last week so when I watching HD movies I can see some black patches when the movie has a night scene... could you please update me whether this is having a problem with dispaly or is it a bug fix to be sorted out in next update ? uploading screenshot for your reference.
  12. N1563011274517
    hey I got it solved I went to one plus store as I am in Bangalore in VR mall I went and got it solved they say that it's bcoz of patch issue..
  13. Shubhraj Sehgal
    Donut Jul 13, 2019
    Shubhraj Sehgal , Jul 13, 2019 :
    what kind of patch software r hardware
    N1563011274517 likes this.
  14. N1563011274517
    not sure bro they took my phone and formatted from their end
  15. Shubhraj Sehgal
    Donut Jul 13, 2019
  16. N1563011274517
    its might be software patch
  17. J1563037789466
    Cupcake Jul 29, 2019
  18. m_world_wide
    Cupcake Aug 18, 2019
    m_world_wide , Aug 18, 2019 :
    I can see linning all over my screen when my phone is on lowest brightness and when my surrounding lights are off ....is my display faulty or it is like this only( please see the image on lowest brightness and in the dark)
  19. Deactivated User
    Aug 20, 2019
  20. Deactivated User
    Aug 20, 2019
  21. m_world_wide
    Cupcake Aug 20, 2019
    m_world_wide , Aug 20, 2019 :
    it the same for all ....i think its the problem with my display cause it doesn't change at all...the lining are same when i.reduce in brightness...and its more visible on white screen
