Battery/Charging OnePlus 7 (non-pro) without Dash Charger
  1. NatalieThomas752
    Cupcake Sep 11, 2019
    NatalieThomas752 , Sep 11, 2019 :
    G'day. I'm sure this might have been asked previously in regards to other phones but since OnePlus is using a slightly different approach in fast charging I thought this discussion has some relevance.
    Theoretically, as with discharging, charging a battery quicker also will deteriorate its life-span overtime. I was wondering whether using the Fast Charger (Dash Charger) every time with the OnePlus 7 (non-pro) degrade the battery capacity eventually. Especially since I'm planning to keep this wonderful device for at least 3 years and then give it to someone in my family.
    So whenever quick charging is not a necessity, Can we just use a generic 5V 1A or 2A charger (obviously, not a cheap knockoff one)? Also, to avoid compatibility issues, with a different charging cable too. I know that DashCharging will be disabled as a result. But, would using a third party charger cause problem on the device's electronics considering OnePlus uses a distinct approach for charging and its safety?
    You may refer the links below for info regarding Fast Charging, Dash Charging, etc.
    Will greatly appreciate your thoughts on this matter.
    Cheers :)
    Reference:
    Fast Charging Explained:
    https://www.androidauthority.com/fast-charging-explained-889780/
    What's Dash Charging?:
    https://www.trustedreviews.com/opinion/what-is-dash-charge-oneplus-3-2936209
    Dash Charging & Cable inter-compatibility:
    https://www.reddit.com/r/oneplus/comments/928iqn/whats_the_difference_between_dash_charge_cables/
    shaikhisa39 likes this.
  2. NatalieThomas752
    Cupcake Sep 12, 2019
    NatalieThomas752 , Sep 12, 2019 :
    I gotta say, every time I come here to ask something there is no response from the community. Seems pretty dead to me :(
  3. ngydat
    KitKat Sep 12, 2019
    ngydat , Sep 12, 2019 :
    Yes you can. Sometimes, I use a powerbank (and there's no powerbank compatible with Dash charge) when there's no outlet around.
    NatalieThomas752 likes this.
  4. luigimario
    The Lab - OnePlus 6T Reviewer Sep 12, 2019
    NatalieThomas752, Baymax and ngydat like this.
  5. ngydat
    KitKat Sep 12, 2019
  6. luigimario
    luigimario , Sep 12, 2019 :
    Yup, and it isn't too expensive either.
    ngydat likes this.
  7. NatalieThomas752
    Cupcake Sep 13, 2019
    NatalieThomas752 , Sep 13, 2019 :
    Good to know. Thanks for the reply
