3
OnePlus 7, notch display setting is not available after Android 10 upgrade
  1. bg.ravikumar
    Cupcake Oct 21, 2019
    siva2014, samsonkeung and javiav79 like this.
  2. M1571637495258
  3. TheULTRON
    Cupcake Oct 23, 2019
  4. tide1109
    Ice Cream Sandwich Oct 24, 2019
    J1508070026278 likes this.
  5. J1508070026278
    Gingerbread Oct 25, 2019
    J1508070026278 , via OnePlus 7 , Oct 25, 2019 :
    Awesome.. whoever found this workaround is pure genius.. works like a charm on my OnePlus 7 (10.0.1)
  6. J1508070026278
    Only mystery now is that if the hide notch native setting is available through Nova activity widget, then why did OnePlus remove the direct settings shortcut for it in Android 10 .. this is strange. For now though, the workaround for accessing the good old hide notch menu mentioned in the post above works perfectly on Android 10.
  7. tide1109
    Ice Cream Sandwich Oct 25, 2019
    tide1109 , via OnePlus 6 , Oct 25, 2019 :
    The changelog of my OP6 says that this feature is currently not available. It's coming back in the next version(s).
    I mean the changelog of the update file and the one in forum.
    I don't know what OnePlus is thinking.
    Re-adding the shortcut isn't hard for the developers.
  8. J1508070026278
    Just noticed that notification bar on top goes completely black (all icons hidden) when i use Uber app after hiding the notch using workaround... maybe they are fixing these type of little bugs before officially reintroducing hide notch option
  9. tide1109
    I don't use this feature on my OP6, even I have the biggest notch on a OnePlus phone. It's not the biggest one overall, but it's not a small as a teardrop notch.
    I think this was already present on Android Pie. Maybe it's the interaction with the new dark mode. I could theoretically be a issues in the Uber app too.
    If it has to much issues, you know how disable this option.
  10. J1508070026278
    yup yup i know how to disable it.. just mentioned the issue from the context of guessing why Oneplus hasnt yet enabled the option officially.. might be due to these little glitches here and there..
