78
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. Titokhan
    Honeycomb Aug 1, 2019
    Ekibyo likes this.
  2. 乾隆皇
    Cupcake Aug 4, 2019
  3. 乾隆皇
    Cupcake Aug 4, 2019
  4. Ahtiong73
    Cupcake Aug 4, 2019
    Ahtiong73 , Aug 4, 2019 :
    I'm wondering if it's possible to load the files via otg ie from a thumb drive onto the root of a Hydrogen OS set, then do the local upgrade method.
    S1562672022549 likes this.
  5. Swejuggalo
    KitKat Aug 4, 2019
    Swejuggalo , Aug 4, 2019 :
    Yepp. Just copy the file from the USB drive to the phone and it be fine
    Ahtiong73 likes this.
  6. Coodex
    Cupcake Aug 8, 2019
    Coodex , Aug 8, 2019 :
    I have OnePlus 7 Pro (EU) version GM1913, I previously installed 9.5.10 AA (International/US Unlocked version) and it seems that it went fine.
    Now I'm trying to install 9.5.11 BA or AA nothing sticks. Anyone experienced the same?
    I'm trying to avoid having to wipe :(
  7. Swejuggalo
    KitKat Aug 8, 2019
    Swejuggalo , Aug 8, 2019 :
    Tried the full update versions?
  8. Coodex
    Cupcake Aug 8, 2019
    Tried flashing the one in OP's first post.
    Rooted with Magisk.
  9. Swejuggalo
    KitKat Aug 8, 2019
  10. Titokhan
    Honeycomb Aug 9, 2019
    Ekibyo likes this.
  11. L1566099340752
    Cupcake Aug 18, 2019
    L1566099340752 , Aug 18, 2019 :
    I have China hydrogen OS 9.5.9
    When I local upgrade to oxygen OS 9.5.11 I got error that downgrade is not possible. Any help is appreciated.
  12. Swejuggalo
    KitKat Aug 18, 2019
    Swejuggalo , Aug 18, 2019 :
    Possible that Oxygen 9.5.11 has a newer date that Hydrogen 9.5.9. Do not update Hydrogen and wait for next Oxygen. That would allow you to change to Oxygen
  13. L1566099340752
    Is there any other ways to upgrade to oxygen without waiting?
  14. Swejuggalo
    KitKat Aug 18, 2019
    You would need a downgrade. There is a post about unbricking 7 Pro devices. That should make it possible to revert back to an older software. If it can flash a bricked device why not a fully functional one.
    I'd guess you don't need to revert to Hydrogen first but could revert to a older international Oxygen and just update that.
    Mega unbricking guide I think the post is called.
  15. L1566099340752
    Thanks, any info about the next oxygen release time? If it's coming soon, I just wait for that.
  16. Swejuggalo
    KitKat Aug 18, 2019
    Everything in between soon and in around 2 weeks would be my guess.
  17. Titokhan
    Honeycomb Aug 29, 2019
  18. joeqt8
    Cupcake Sep 10, 2019
    joeqt8 , Sep 10, 2019 :
    Hi everybody!
    I'm here too since I think i've just madre a BIG mistake. Flash TWRP to Ramdisk Boot Partition and now it's stuck to only Fastboot Mode. Event if I try to select Recovery or System, it keeps on going back to Fastboot Mode.
    Having said this, which file should I download since I have a GM1910 Version from Gearbest with OxygenOS preflashed.
    Please Help  Thank you in advance
  19. Titokhan
    Honeycomb Sep 11, 2019
  20. darkarvan
    Gingerbread Sep 13, 2019
    darkarvan , Sep 13, 2019 :
    @Titokhan if i flash the zips above to switch from AA to BA via local upgrade, does it include the latest recovery too or to i need to flash it manually?
    edit: answer is yes. the full package contains everything
