78
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. ZacharyNJBarker95 , via OnePlus Community App , Dec 21, 2019 :
    lot of bug's & that with the android 10 on 7Tpro 5G if you actually look into it plus you are right in a way due to the specs being pretty much the same to the 7 Pro 5G
  2. J_Duece_81
    Gingerbread Dec 23, 2019
    J_Duece_81 , via OnePlus 5T , Dec 23, 2019 :
    Wow this thread is great, lots of community support, I love it. I'm hoping to get my hands on a US 8/256G 7pro, they went out of stock before I could purchase one. Besides that I would like to make sure that the ROM's listed here can be used via the stock updater, I don't have access to a computer. Keep up the good work.
  3. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 23, 2019 :
    Yeah. They are used in the local upgrade option in the phone. As long as it is not a carrier branded and locked version it's possible to upgrade manually.
  4. 8142881429
    Cupcake Dec 25, 2019
  5. KARTHIK.NAIDU
    Cupcake Jan 6, 2020
  6. D1568324392283
    Cupcake Jan 6, 2020
    D1568324392283 , Jan 6, 2020 :
    its not getting flashed it says the ota update chosen is old downgrading is not allowed what should i do
  7. H1575565685443
    Cupcake Jan 14, 2020
  8. AhmedNour
    AhmedNour , Jan 14, 2020 :
    hi
    my Op7pro is on 10.3.0 GM21AA
    my device is GM1913
    how I downgrade it to 10.0.2 ?
    Also is this downgrade will remove all the data on phone ?
  9. darkarvan
    Gingerbread Jan 22, 2020
    darkarvan , Jan 22, 2020 :
    @AhmedNour
    you cant downgrade, its locked.
    you would use the hard brick tutorial method or use an old android 9 rom, in both cases all data were wiped form your phone.
    why do you want to downgrade? you are on non EU Build currently, if you want to switch back to EU build line, wait till next stable update and cross flash, your data should be fine.
    AhmedNour likes this.
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 23, 2020 :
    Update/Downgrade your phone with starting from the community app. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/. Video http://bit.ly/37ss8mI
    After don't use OTA. Install the EU version you need manually.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
  11. AhmedNour
    Cupcake Jan 23, 2020
    AhmedNour , Jan 23, 2020 :
    darkarvan
    @AhmedNour
    why do you want to downgrade? you are on non EU Build currently, if you want to switch back to EU build line, wait till next stable update and cross flash, your data should be fine.​
    After latest update battery drains heavily, charging speed decreased and multiple bugs occurred !!
    the phone was fine at 10.0.2 and I hope next update will solve these problems
    ZacharyNJBarker95 likes this.
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 25, 2020 :
    T-mobile 10.0.2 does not nessesarilly have much incommon with regular 10.0.2. See those versions as completely separated from original version numbers.
  13. 143@papa
    Cupcake Feb 4, 2020
  14. The_Unkown
    Jelly Bean Feb 8, 2020
  15. The_Unkown
  16. Yadavchinna
    Cupcake Feb 8, 2020
    Yadavchinna , Feb 8, 2020 :
    Android setup keep stopping
    the above pop up coming while starting the new 7pro mobile
  17. darkarvan
    Gingerbread Feb 12, 2020
  18. Swejuggalo
    KitKat Feb 12, 2020
