101
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. Dronzer99
    Cupcake Mar 8, 2020
    Dronzer99 , Mar 8, 2020 :
    alright boss
  2. StopItRawr
    Ice Cream Sandwich Mar 9, 2020
    StopItRawr , Mar 9, 2020 :
    It wont.
    The 5G OnePlus 7 Pro has a Chip (The SD 855+X50) that was not released in India.
    It's not a software feature.
  3. vijay.kumar354
    Gingerbread Mar 30, 2020
  4. Igo Kap Linsky
    Cupcake Apr 3, 2020
    Igo Kap Linsky , Apr 3, 2020 :
    Hi guys
    I have a problem with my new oneplus 7pro 5g custom twrp was installed but by mistake I made a full format and closed bootloader. I can't do anything
  5. Swejuggalo
    Lollipop Apr 3, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 3, 2020 :
    I'm not so sure there is much you can do with the 7 series 5G versions... Is even anything at all compabitle with them? General advice... Unless clearly mentioning 5G don't use it on a 5G device.
    You may need the help of a service center...
  6. Igo Kap Linsky
    Cupcake Apr 10, 2020
    Igo Kap Linsky , Apr 10, 2020 :
    Hi guys
    Problem solved one plus support team sent me firmware for my GM 1920 . But I have another problem I can't install custom. For 5G should be another firmware or something?
    Thanks
  7. J_Duece_81
    Gingerbread Apr 10, 2020
    J_Duece_81 , via OnePlus 7 Pro Mirror Gray , Apr 10, 2020 :
    Did you try reaching out to anybody at XDA? I don't mess with this stuff personally but I like to read about it. They did list the gm1920 as twrp supported. Take care, good luck.
  8. fahadleee
    Gingerbread Apr 12, 2020
  9. fahadleee
    Gingerbread Apr 28, 2020
  10. sonnyhaze
    Gingerbread May 3, 2020
    sonnyhaze , May 3, 2020 :
    on the OnePlus 7 Pro 5G from Sprint, if you had access to the system page (like the page unlocked phones show, with the gear in the up right corner), would you be able to install the dual SIM version.
    Because I have found a way to access it but I don't know which version I need. it shows the forklift saying root directory empty.
    do I need the op 7 pro 5g(eu)?
  11. Swejuggalo
    Lollipop May 3, 2020
    Swejuggalo , via OnePlus 7 Pro , May 3, 2020 :
    5G EU would be the closest... Even if you could flash it's not certain the network would work for you
  12. SATISH.D.S
    Froyo May 3, 2020
  13. G_Wing_So_UwAJ
    Cupcake May 7, 2020
  14. Y1588872264849
    Cupcake May 7, 2020
    Y1588872264849 , via OnePlus 7T , May 7, 2020 :
    Hello,
    Since last one week happened a very strange thing.
    While i was using teamviewer, suddenly the Oneplus 7 frozen and unresponsive. I tried to keep the power button pressed for 60 seconds but it doesn't reboot, i also tried with power btn and vol- but the Oneplus7 was still frozen.
    The only way to make it reboot was to keep pressed Vol+, Vol- and power btn.
    After the reboot the smartphone is also not functioning.
    Is this One plus team cheating on the people????.
    It is not doing justice for the purchased price..
    kindly resolve my issue...I have been struck with this problem.
    Mod Edit
  15. Abhishek R Sharma , via OnePlus 7 Pro , May 14, 2020 :
    my phone's bottom speaker not working properly... while playing games or watching YouTube videos sometimes it gets Cut off... please help for this... reboot was already done but useless
  16. sonnyhaze
    Gingerbread May 17, 2020
    sonnyhaze , via OnePlus 7 Pro , May 17, 2020 :
    Does anyone know how to remove network lock on rooted OnePlus 7 Pro 5G Sprint.
    I was able to root it (which new at) and thought that would override the OEM lock, but it's still greyed out and locked to sprint.
    I got the damn phone off eBay and thought it was unlocked so I can't unlock it by calling sprint.
  17. kranthiNaidu
    Cupcake May 18, 2020
  18. Swejuggalo
    Lollipop May 18, 2020
    Swejuggalo , via OnePlus 7 Pro , May 18, 2020 :
    5g needs a 5g modem. Regular versions don't have that
