39
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. Z1527041461816 Cupcake Jun 6, 2019
    Titokhan likes this.
  2. Titokhan Honeycomb Jun 7, 2019
  3. Viswa Suhaas Penugonda Cupcake Jun 7, 2019
    Viswa Suhaas Penugonda, Jun 7, 2019 :
    @Titokhan I've flashed Oxygen OS on Hydrogen OS by local upgrade method but I'm not getting the next OOS updates. What should I do? Should I always download OOS updates and install?
  4. Titokhan Honeycomb Jun 7, 2019
  5. raywjr26 Cupcake Jun 9, 2019
    raywjr26, Jun 9, 2019 :
    Hi guys. The main differences between Hydrogen OS and Oxygen OS is only the pre-installed Google apps?
    Other than that, everything is the same?
  6. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 9, 2019
    AnonymousWP, Jun 9, 2019 :
    Nope, also more bloat and not as good privacy-rules.
  7. G_Pavan_P_aoMh Eclair Jun 10, 2019
    G_Pavan_P_aoMh, Jun 10, 2019 :
    Hi,
    How do we know which is Hydrogen and which is Oxygen build? i bought my phone in India, but i am residing in EU, can i install the EU version of 9.5.7 ?
  8. texane Cupcake Jun 10, 2019
    texane, Jun 10, 2019 :
    H1560074497143 said: ↑
    I know that china rom is not support Google play, so I had sucess to chage and update the latest Oxygen OS 9.5.7GM 21AA. but can't success use for google pay when add bank card . And this google play show this device isn't play protect authorization.
    For those who switched from Hydrogen to OOS, do you have the same issue with the chinese version? Thanks.
  9. geo07 Ice Cream Sandwich Jun 11, 2019
    geo07, Jun 11, 2019 :
    I have flashed several 7 pro devices , Chinese version to Oxygen OS and none of these have any problems either with Google play protect or device certification including the one I'm using now. In my device though, I haven't enabled Google pay because I live in HK and China that everyone uses alipay or wechat pay but I know a Dutch couple that I got for them 2 of the exact same devices tand flashed Oxygen OS, they use Google pay in Netherlands.
    texane likes this.
  10. texane Cupcake Jun 11, 2019
    texane, Jun 11, 2019 :
    Hello, ok so i will ask support if needed.
    Which OOS version did you use to flash? (link if possible, thanks).
    Where did you buy the o+7 pro? In HK or China? Version 1910, right ?
    Thanks a lot.
  11. JoseReyes69 Gingerbread Jun 11, 2019
  12. geo07 Ice Cream Sandwich Jun 11, 2019
    texane
    Thanks a lot.​
    My version of OnePlus 7pro is GM 1910, the Oxygen OS is 9.5.7 GM 21ba. It works like a charm!
    In mainland China you can buy from J D online store, they have available now. Some people here say that in some Sundan appliance stores they sell too but in my city I haven't seen any. Of course from the official site too.
  13. Saifmsk Cupcake Jun 12, 2019
    Saifmsk, Jun 12, 2019 :
    Did you get it as OTA? It's been over 6 days and I still haven't received the OTA for 9.5.7.
    I have the GM1910 version with oxygenos 9.5.5
  14. geo07 Ice Cream Sandwich Jun 12, 2019
    geo07, Jun 12, 2019 :
    Saifmsk
    I have the GM1910 version with oxygenos 9.5.5​
    I used VPN to Germany and got it. Alternatively you can use the oxygen updater app.
  15. texane Cupcake Jun 12, 2019
    texane, Jun 12, 2019 :
    Thanks.
    I have just bought it tonight. Should play with tomorrow :)
  16. Saifmsk Cupcake Jun 12, 2019
    ah I tried nordvpn but it keeps timing out.
    I think I'll just wait for the update.
  17. geo07 Ice Cream Sandwich Jun 12, 2019
    Any help just buzz me!
    texane likes this.
  18. vexbit Cupcake Jun 12, 2019
    vexbit, Jun 12, 2019 :
    @dannbass11 @thidge Just had a quick go at flashing my GM1920 which I got from EE with the 1910 firmware - It's a no go. The recovery rom does not have sideload nor local flashing capability, and the local upgrade via the settings has been disabled too. Looks like EE has asked OnePlus to cripple the firmware.
    This really sucks, I thought the days of carriers interfering with firmwares were behind us, but apparently not. I also tried VPN'ing to different places in the world to try and get the update - That times out because I suspect the server we're connecting to for our updates is from EE not OnePlus. So I'm seriously not happy about that - Debating handing my phone (and contract) back to EE, and buying a retail version direct from OnePlus. I'd rather have direct updates than 5G.
    My hyperbole aside, it's also very likely that OnePlus hasn't actually pushed the firmware for the GM1920 yet; it has different firmware than the 1910 because the 5G is a separate modem chip, and isn't on the SoC. Just gotta be a bit more patient I guess.
    dannbass11 likes this.
  19. texane Cupcake Jun 13, 2019
    texane, Jun 13, 2019 :
    thanks for your support.
    I have just installed the last version OnePlus7ProOxygen_21.E.11_OTA_011_all_1906040003 then erase all data + wipe cache.
    It sounds good. Need to go back home to have a vpn to use google & co :)
    geo07 likes this.
  20. Titokhan Honeycomb Jun 18, 2019
    texane and geo07 like this.
