36
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. Titokhan Honeycomb Jun 20, 2019
    H1558888838801 and geo07 like this.
  2. H1558888838801 Cupcake Jun 20, 2019
    H1558888838801, Jun 20, 2019 :
    Hello Boss and thanks for the updated files
    I'm currently in China and have bought the 7Pro GM1910 which arrived this morning, it came with the HydrogenOS installed.
    https://prnt.sc/o48elb
    I wanted to switch to Oxygen so i downloaded this 9.5.8 and updated via the "Local Upgrade" in the settings.
    Looks like it all went well, after the phone reboot i can see that it is OOS 9.5.8 GM21AA now.
    https://prnt.sc/o48px0
    I can also see that the One Plus Market and other chinese bloatwares that came with hydrogen os disappeared and a bunch of google apps have been added to the app drawer. However, for some reason, it seems like i'm missing google play and perhaps other necessary gapps?
    https://prnt.sc/o48pfi
    And another weird thing happening is this "Preparing for setup" screen. although i can exit and comeback to this screen, it doesn't seem to be doing anything. it's not downloading any apps nor starting a setup process. it's just stuck like this. i dont know if it's my internet connection (i've tried connecting to VPNs) and to our VPN router but to no avail.
    https://prnt.sc/o48pnu
    Would love to get help and tips on how i can add those gapps missing as well as finish this whole "Preparing for setup" screen.
    thank you in advance everyone!
  3. geo07 Ice Cream Sandwich Jun 20, 2019
    geo07, Jun 20, 2019 :
    H1558888838801
    thank you in advance everyone!​
    After you flash Oxygen OS over hydrogen you need to full
    reset the device or wipe data and cache from the recovery. Then you will be alright. By the way you flashed the whole 9.5.8 ROM right?
    texane and Ahtiong73 like this.
  4. H1558888838801 Cupcake Jun 20, 2019
    hey there. yeah, on my way to rooting which wipes data, all the necessary gapps turned up after... now everything seems to be working fine. i enabled the 90hz to all apps as well... smooth AF
    any magisk module recommendation? so far i've only installed FDE.ai
  5. mikey Gingerbread Jun 23, 2019
    mikey, Jun 23, 2019 :
    quick q. i have the GM1910 running international build GM21AA. works great and VoLTE and VoWIFI works out of the box (on THREE UK).
    is it worth changing to the EU Build, or shall i just leave everything as it is ?
  6. H1558888838801 Cupcake Jun 24, 2019
    H1558888838801, Jun 24, 2019 :
    Well you know what they say, if it aint broke don't break it :D
  7. ColdHell Donut Jun 26, 2019
    ColdHell, Jun 26, 2019 :
    Hi I just received my OnePlus 7 Pro 1910. I tried the local upgrade method but it kept saying that "The version of your selected package is lower than the current system". Can someone help me?
  8. geo07 Ice Cream Sandwich Jun 26, 2019
    geo07, Jun 26, 2019 :
    Did you install any updates with hydrogen after you turned on the phone?
  9. ColdHell Donut Jun 26, 2019
    Yeah it was an auto update.
  10. G_john_Knaggs_BMvk Cupcake Jun 26, 2019
    G_john_Knaggs_BMvk, Jun 26, 2019 :
    Hi,
    quick question, if i purchase a 7pro 5G, would it be possible to change firmware to 7PRO non 5G variant, then at a later date revert back to 5G firmware. I realise i would lose 5g capability but would i gain dual sim support? Its all to do with own and work phones changing later this year. Ive looked everywhere XDA etc. but found no definitive answer. Hoping you folks may be able to steer me in the right direction. Thanks in anticipation.
  11. geo07 Ice Cream Sandwich Jun 26, 2019
    Now if you want to do it this way you need to wait for an oxygen ROM that it will higher version from the hydrogen you auto updated...
  12. ColdHell Donut Jun 26, 2019
    Is there no other way to undo the update? Is there any other method besides rooting?
  13. geo07 Ice Cream Sandwich Jun 26, 2019
    I'm always using that method, to be honest it happened to me some years ago with my 3 but luckily an update came up the next day and it was ok right after! So, after that I learned about it, every time when I get a new device with Hydrogen I cut any network when I first turn on the phone , copy the ROM and install it straight. Another way maybe exists, but I haven't tried it. Sorry mate.
  14. ColdHell Donut Jun 26, 2019
    Well, lesson learned I guess. I highly doubt that there will be a new update anytime soon as 9.5.8 are fairly new. Then again, I really appreciate the effort. Thanks man
    geo07 likes this.
  15. ColdHell Donut Jun 26, 2019
    Sorry to disturb you again. But is there a guide on how to root the phone? I really need to use the phone right now. Using an android phone w/o google play store pretty much a nono
  16. geo07 Ice Cream Sandwich Jun 26, 2019
    ColdHell
    Sorry to disturb you again. But is there a guide on how to root the phone? I really need to use the phone right now. Using an android phone w/o google play store pretty much a nono​
    I'm the wrong person to ask about rooting! Try to search here in the forum about rooting a 7 pro and if you can't find anything helpful you can open a thread and request for help. I never rooted or jailbreak a phone before, not even changed a launcher, I really like the stock feeling and that's why I like to use OnePlus and iOS! BTW my pleasure to help if I can, if I'm late to reply means I'm sleeping, in my time zone is already midnight!
  17. Titokhan Honeycomb Jun 26, 2019
  18. Liduang1 Cupcake Jun 27, 2019
    Liduang1, Jun 27, 2019 :
    Please help.
    I tried to use Oxygen OS 9.5.8 that you posted to update from Hydrogen OS 9.5.6GM21.
    It showed the version that I selected is lower than current system.
    Is it possible to fix it?
  19. odysseas76 Cupcake Jun 27, 2019
    odysseas76, Jun 27, 2019 :
    I have oneplus 7 pro with 9.5.7 rom. I have twrp and magisk root.
    How can I use those zip files to update to 9.5.8 version?
  20. S1561740932366 Cupcake Jun 28, 2019
