36
[OnePlus 7 Pro (5G)][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. S1561740932366 Cupcake Jun 28, 2019
    ColdHell, geo07 and Titokhan like this.
  2. danmeuk Eclair Jun 29, 2019
    danmeuk, Jun 29, 2019 :
    I saw someone tried this in the forums... the phone will boot, but have no connectivity (including wifi!) so... no, you can't run the non-5G firmware on the 5G device (a definitive answer!)
    You can tell the 5G firmware not to try to negotiate 5G in the settings for the SIM though.
    NOTE: the 5G model is single sim only! If you need dual sim capability then you need to buy the non-5G model.
    G_john_Knaggs_BMvk likes this.
  3. G_john_Knaggs_BMvk Cupcake Jun 29, 2019
    G_john_Knaggs_BMvk, Jun 29, 2019 :
    Ok, many thanks for that.
    danmeuk likes this.
  4. G1560547730992 Cupcake Jul 1, 2019
    G1560547730992, Jul 1, 2019 :
    Did you install Oxyzen OS from Hydrozen OS?
  5. kikuchanjzh Donut Jul 1, 2019
    kikuchanjzh, Jul 1, 2019 :
    sorry, no. I bought op7 pro in the US finnally.
  6. Titokhan Honeycomb Jul 5, 2019
  7. G1513131415671 Cupcake Jul 6, 2019
    G1513131415671, Jul 6, 2019 :
    Hi, I need some help here. I was using model GM1910 which preinstalled latest Hydrogenos. I wish to local upgrade to Oxygenos GM21AA but failed because it said due to 9.5.8 rom lower than my current rom. Is it what I can do for now is wait for next update from Oxygenos only able to local upgrade it? Thanks
  8. Killian COMPAGNON Eclair Jul 6, 2019
  9. Ekibyo Cupcake Jul 6, 2019
    Ekibyo, Jul 6, 2019 :
    I am new to this so i am sorry if my questions are stupid.
    I will get soon a oneplus7 pro gm1910 with hydrogenos and i would like to have oxygenos.
    1. What is the difference of this files and what should i install:
    Signed flashablezips
    Stock boot-recovery images
    2 If i do this when new os version is up i will get it auto or i will need to do the local instal again
  10. Sandrobey Cupcake Jul 7, 2019
  11. Swejuggalo Ice Cream Sandwich Jul 7, 2019
    Swejuggalo, Jul 7, 2019 :
    China 7 Pro version right? From what I have read before it should not matter what version you choose. GM21AA software is updated a few minutes before the EU version. Unless you live in EU you could just as well go with GM21AA instead of GM21BA. You don't actually make it a GM1913, you just change the software... The phone will still show GM1910.
  12. Sandrobey Cupcake Jul 7, 2019
    Sandrobey, Jul 7, 2019 :
    Thanks for your information. I was just wondering because I've come to the conclusion that, for some reason, it's the model number which doesn't let me play Fortnite on 60fps. I've heard some other people have managed to get Fortnite on the oneplus 7 pro with 60 FPS, and this is the only reason I can come up with.
  13. puLse2D Jelly Bean Jul 8, 2019
  14. amralkareem Cupcake Jul 10, 2019
    amralkareem, Jul 10, 2019 :
    i have oneplus 7pro i download last ver GM21AA 9.5.8 okmy phone is GM1910 chine ok when i upgrade
    it in local it says the version of your selected pack-age is lower thanthat of the current system my system is hydrogen os 9.5.6 gm21 what can i do
  15. Swejuggalo Ice Cream Sandwich Jul 10, 2019
    Swejuggalo, Jul 10, 2019 :
    amralkareem
    it in local it says the version of your selected pack-age is lower thanthat of the current system my system is hydrogen os 9.5.6 gm21 what can i do​
    Maybe you download the full install of 9.5.9 with Oxygen Updater and see if that works. If I find direct links I'll post them soon
    OOS 9.5.9 GM21AA full zip: https://otafsg1.h2os.com/patch...012_all_1907050210_573f8fa.zip
    amralkareem likes this.
  16. geo07 Ice Cream Sandwich Jul 10, 2019
    geo07, Jul 10, 2019 :
    What's the difference between GM21AA and GM21BA? I also have the Chinese version flashed from Hydrogen but it has the 21BA not the 21AA.
  17. Ekibyo Cupcake Jul 10, 2019
  18. Ekibyo Cupcake Jul 10, 2019
    Ekibyo, Jul 10, 2019 :
    If i flash any oxygen version will i get auto updates after? or when new version come need to flash manual again ?
  19. ColdHell Donut Jul 11, 2019 at 2:10 AM
    ColdHell, Jul 11, 2019 at 2:10 AM :
    You will automatically get the updates afterward
    Ekibyo likes this.
  20. ColdHell Donut Jul 11, 2019 at 2:14 AM
    ColdHell, Jul 11, 2019 at 2:14 AM :
    Check PM
