OnePlus 7 Pro 5Ghz Wifi Issue via OnePlus 7 Pro
  1. AjmalAksar
    Cupcake Mar 20, 2021
    AjmalAksar , via OnePlus 7 Pro , Mar 20, 2021 :
    I recently updated to the beta version of Android 11. However, now I am not able to connect to any 5Ghz bandwidth wifi near me. It just doesn't connect
    Whenever I try to connect, It just shows unable to connect and connects to the 2.4Ghz wifi. The same is happening with another 5Ghz wifi I'm using. At first I thought it was because of the router. But then, every other device of mine except the phone has been able to connect to it
    PS: the phone had fallen from my hand quite a few times. could the fall have done any damage to the internals? The Display itself is quite washed up due to the falls
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Mar 20, 2021
    Artemus , Mar 20, 2021 :
    5 GHz is like 5G: it sucks at penetrating through walls and anything around the signal that could block it. So unless you're right next to the router (or in the same room as it) it's 2.4 for you.
    J4t1np4r3kh likes this.
  3. AjmalAksar
    I'm literally sitting right beside it.
    When checking through an app, ip showed this.
  4. Artemus
  5. AjmalAksar
    I really don't know. I just wanted to check if it supports 5Ghz and apparently it doesn't now. I really just wanna solve this issue
  6. Artemus
    Does your router have dual-band support in the first place, if you know?
  7. hbk1402
    KitKat Mar 20, 2021
  8. AjmalAksar
    I just tried this right now. Didn't work. How do I report it?
  9. hbk1402
    KitKat Mar 20, 2021
    hbk1402 , via OnePlus 7 Pro , Mar 20, 2021 :
    Open my community app. Go to my profile-> My feedback -> click on plus icon -> under Bug Report -> Select the appropriate section and report your issue
  10. Tobikage
    Nougat Mar 20, 2021
    Tobikage , Mar 20, 2021 :
    Post issues in the Beta thread if you're using the Beta....simple as that.
  11. AjmalAksar
    Thank you
  12. hbk1402
    KitKat Mar 20, 2021
  13. MaxDaddy69
    Cupcake Mar 22, 2021
    MaxDaddy69 , Mar 22, 2021 :
    What speed is your internet? Unless you are on 100Mbps+ it will make little difference.
  14. H1568986118719
    Cupcake Mar 27, 2021
  15. elmasrydev
    Cupcake Oct 20, 2021
    elmasrydev , Oct 20, 2021 :
    I got same issue on my 6T and fixed it by changing transmitting channel of 5GHz WiFi to any of these channels 36 , 40, 44 , 48. Good luck.
