55
OnePlus 7 Pro - A Review
  1. iamPhinnyJT Cupcake Jun 6, 2019
    iamPhinnyJT, Jun 6, 2019 :
    Slight disappointed that USB C to 3.5mm adapter was not provided.
    Hope uncoming phone it will be provided.
    And also phone of Rs. 48000 and above should have wireless earphones or Wored earphones.
    It will be best add on for Loyal Customers.
    #41
    brian.sedore likes this.
  2. coachfelder Donut Jun 6, 2019
    #42
    MR.BEN312 likes this.
  3. krazor8x Eclair Jun 6, 2019
    krazor8x, Jun 6, 2019 :
    I've noticed the I get better consistent photos when mounting the phone to a tripod like device, and using a Bluetooth button to take the pic, seems it may need software tweaks to help compensate for unsteady hands.. Or at least mine
    #43
  4. RAHUL2VIJAY Eclair Jun 6, 2019
    RAHUL2VIJAY, Jun 6, 2019 :
    is tempered glass protection is available for these phone.i am from India is any official release coming?
    #44
  5. K1508765621572 Cupcake Jun 6, 2019
    K1508765621572, Jun 6, 2019 :
    Hello Team, Is someone facing issue with display sometimes it behave like Someone other controlling my mobile.
    #45
  6. brian.sedore Honeycomb Jun 6, 2019
    brian.sedore, Jun 6, 2019 :
    Haven't had that, but I think if you check out a video xdadevelopers had on YouTube, he might be experienced "phantom touches".
    #46
  7. MR.BEN312 Honeycomb Jun 6, 2019
    #47
  8. brian.sedore Honeycomb Jun 6, 2019
    Still evaluating that, but I would say that overall it's better. Without going to in-depth, there is a telephoto lens if you need to zoom; a wide angle for more subjects in the photo; and the OIS is a welcomed addition if you're coming from the 5T.
    It was suggested that I wait for a camera update to better compare. Once another update comes, I'll try to post before update, after update, and 5T samples.
    #48
  9. brian.sedore Honeycomb Jun 6, 2019
    Good suggestion, but I don't feel like it should have to come to using a tripod or steadying the device just to get consistently quality photos.
    #49
  10. G_Anand_Lal_ZWCv Cupcake Jun 7, 2019
    #50
  11. csrcsr07 Marshmallow Jun 7, 2019
    #51
  12. S1560042988894 Cupcake Jun 9, 2019
    #52
  13. MR.BEN312 Honeycomb Jun 9, 2019
    #53
  14. C1559662135646 Cupcake Jun 9, 2019
    C1559662135646, Jun 9, 2019 :
    hii I'm using oneplus7pro with the OS 9.5.4. no update post that..the phone is heating up drastically while using generally as well.. not playing games.. not watching movies videos nothing.. don't know if the issue is with my device or someone else is also facing the same .
    #54
  15. brian.sedore Honeycomb Jun 10, 2019
    brian.sedore, Jun 10, 2019 :
    Doesn't sound normal. You are not doing anything with the phone and it's heating up? Probably should check with support. There is an update going around that may or may not help with that.
    #55
  16. MR.BEN312 Honeycomb Jun 11, 2019
    MR.BEN312, Jun 11, 2019 :
    your best bet is to call OnePlus customer support...
    #56
  17. ANUBHAV KUMAR PANDEY Cupcake Jun 11, 2019
    ANUBHAV KUMAR PANDEY, Jun 11, 2019 :
    agree
    #57
    MR.BEN312 and C1559120274402 like this.
  18. MR.BEN312 Honeycomb Jun 11, 2019
    #58
  19. O1560364041205 Cupcake Jun 12, 2019
    #59
  20. C1559662135646 Cupcake Jun 12, 2019
    C1559662135646, Jun 12, 2019 :
    really... there seems to be some issues popping up abruptly... after latest update now the cells heats up even more be it while charging on idle or due to continuously using for calling purpose.. even the battery doesn't stay more than 10-12 hours if fully charged in the morning and mind u only used for office purpose..calling emailing documents etc... not expected this.. shifted from iPhone to one plus.. not the best experience till now..
    #60
