OnePlus 7 Pro Almond gold have dark shade via OnePlus 7 Pro
  1. OnePlus Veroy
    Cupcake Apr 23, 2020
  2. spot01
    Jelly Bean Apr 23, 2020
    Garry-Lewis likes this.
  3. Secondbushome
    Honeycomb Apr 23, 2020
  4. OnePlus Veroy
  5. Secondbushome
    Secondbushome , via OnePlus 7 Pro , Apr 23, 2020 :
    I don't have a second camera right now to take a picture of the phone but I can definitely confirm that it is a different shade of gold. I remember noticing it right out of the box.
    There are also some YouTube tech reviews that pointed it out.
  6. OnePlus Veroy
  7. Secondbushome
    Nothing that I would recommend. That's just the way the finish looks. You wouldn't be able to make it look lighter.
  8. OnePlus Veroy
  9. Secondbushome
    No, the paint on the aluminum is under a layer of sealer. You can't just 'clean' the color away, you would have to completely removed the sealer and paint and then repaint and reseal it, which would be pretty extreme and should only be done by a professional.
    If it really bugs you that much, the best advice would be to sell it and get another color.
  10. OnePlus Veroy
  11. OnePlus Veroy
    Cupcake Apr 24, 2020
  12. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Apr 24, 2020
    Liehjan , Apr 24, 2020 :
    Polish?
  13. OnePlus Veroy
  14. spot01
    Jelly Bean Apr 24, 2020
  15. OnePlus Veroy
  16. OnePlus Veroy
    Cupcake Apr 25, 2020
  17. OnePlus Veroy
    Cupcake Apr 26, 2020
  18. OnePlus Veroy
    Cupcake Apr 30, 2020
  19. Vligthart
    Vligthart , Apr 30, 2020 :
    let it go dude.
    There is nothing you can do to change the colour to match the rest.
    I suggest you put a sticker on it if it bothers you this much.
    E1558912633684 likes this.
  20. Z1576130185201
    Cupcake Oct 18, 2020
