38
Oneplus 7 Pro ambient display not working
  1. Pihgg Cupcake May 27, 2019
    Pihgg, May 27, 2019 :
    I've tried both and neither one is working.
    x Stobbart x likes this.
  2. gravage Eclair May 27, 2019
    gravage, May 27, 2019 :
    People saying that it's working fine for them simply aren't in the right conditions to replicate the issue. Mine will work fine for a while, then simply stop working in a dim environment. I have updated to the latest version, cleared all of the caches, and restarted several times. No, it's not working fine. There's still a bug with the light sensor.
  3. Pihgg Cupcake May 27, 2019
    I noticed that if I have been using my phone in daylight for example, turn off the display, and go to a darker environment, ambient display will work but only once. This seems to be the only case when it works for me in darker environments. I truly hope this will get fixed.
  4. x Stobbart x Donut May 27, 2019
    x Stobbart x, May 27, 2019 :
    I leave the phone turned on when I sleep (obviously deep dark) it works before I fall asleep and it works also in the morning after one night of dark...
  5. S1541656739596 Cupcake May 27, 2019
  6. jdgesmlls Donut May 27, 2019
    jdgesmlls, May 27, 2019 :
    A different update than 9.5.4 for GM1917 and 9.5.5 for GM1913?
    Do you have a source?
  7. gravage Eclair May 27, 2019
    I have the update. It didn't fix it.
  8. YMark Cupcake May 27, 2019
    YMark, May 27, 2019 :
    Same here. I think this was just a bone to call off the dogs for a day. All it did was aggravate them even more.
  9. Nello87 Cupcake May 27, 2019
    Nello87, May 27, 2019 :
    No funziona il display ambiente!
    Vorrei che il problema fosse risolto quanto prima!
    A1558130198159 likes this.
  10. haroldmelendez Cupcake May 28, 2019
    haroldmelendez, May 28, 2019 :
    my oneplus 7 pro from Tmobile has the same problem. I had an security patch update for april yerterday but the problem still there. The double tap to wake does not work and the pick your phone to wake also does not work. It works randomly and as i read from previous chats, it looks like there is a bug with the light sensor, i am not sure but it could be the reason.
    Please oneplus send an update to solve this issue, this is a frustrating issue with a new phone. Do not wait until unbox therapy show this problem in his youtube channel where millions of people could learn about this and other issues and not buying this phone anymore. Thank you
    update, i have the tmobile version for United States 8 GB Ram and 256 GB. Model GM1915 Build Number Oxygen OS 9.5.6 GM31CB
    I have the Security patch level : April 1, 2019
    The ambient display and the double tap to wake are working randomly, when i move the phone from a light place to a dark place. The horizontal light feature works with delay. Please i need the update.
  11. rclotz Honeycomb May 28, 2019
    rclotz, May 28, 2019 :
    I also had the low light issue but after the last update, my phone has no more problems.
    Ambient display, notifications as well as double tap is working as expected. No matter if daylight, low light or night.
    So everything is fine since 3 days.
  12. haroldmelendez Cupcake May 28, 2019
  13. rclotz Honeycomb May 28, 2019
  14. haroldmelendez Cupcake May 28, 2019
  15. Nicotin3 Cupcake May 28, 2019
  16. Hutch81 Eclair May 29, 2019
    Hutch81, May 29, 2019 :
    1.Go to dialer and enter *#808#
    2. Go to device debugging tab and select proximity sensor test.
    3. Make sure nothing is covering the phone and tap the offset calibrate button until you see the pass notification. Do this for both the 2cm and 4cm thresholds .
    4. Close the dialer and select double tap to wake ...success!
  17. U1558102992008 Cupcake May 29, 2019
    U1558102992008, May 29, 2019 :
    This worked for me but will this be a temporary fix is the question
  18. Michael S. Nielsen Eclair May 29, 2019
  19. U1558102992008 Cupcake May 29, 2019
    Are you with T-Mobile?
  20. Michael S. Nielsen Eclair May 29, 2019
    U1558102992008 likes this.
