OnePlus 7 Pro and referral Points - Does voucher work on Phone purchase or only accessories?
  1. Adam276 Gingerbread May 23, 2019
    Adam276, May 23, 2019 :
    Does anyone know if I redeem the 1000 points for $100 Coupon off the OnePlus store, can it be used on the phone itself, or only cases and charges and items like that?
  2. bhaumikbheda Gingerbread May 23, 2019
  3. Adam276 Gingerbread May 24, 2019
    Adam276, May 24, 2019 :
    are you sure that includes $100 off a phone? I heard mixed comments on that and haven't heard someone confirm it works on a phone.
    if it does then that's awesome.
  4. bhaumikbheda Gingerbread May 24, 2019
  5. meatandy Nougat May 24, 2019
    meatandy, May 24, 2019 :
    Should take $100 off anything more than $100 and the referral section.
    Are you currently able to enter the referral page ? I haven't been able to get in for 2 days .
  6. Adam276 Gingerbread May 24, 2019
    That's the problem, they said it should but no definitive answer. I spoke to a rep on the phone and she said if it doesn't work call and they help add it but I can't get a definitive response.
    Trying to see if there is anyone that tried it.
  7. Adam276 Gingerbread May 24, 2019
    I'm able to get it and redeem. But I always thought it was $ off stuff like cases, never thought it was off the phone too as I never tried that.
    Wonder if anyone has.
    meatandy likes this.
  8. meatandy Nougat May 24, 2019
    I've only used my referral points on phones as a whole.
    Adam276 likes this.
  9. bhaumikbheda Gingerbread May 24, 2019
    bhaumikbheda, May 24, 2019 :
    As far as what I can see written on the coupon (Accessories and Gear), I think whatever falls under these 2 categories only they can be redeemed through the discount.
    Drop an email to them so that you have written proof saying that it works or not.
  10. meatandy Nougat May 24, 2019
    Yeah you're lucky I can't even get into the page.
    @Crystal Z. Can you confirm any of the above questions and issue with the referral page?
  11. Adam276 Gingerbread May 24, 2019
    Oh wow, I never knew that!
    I was going to use the student discount for the 7Pro and didn't even realize I could use $100 off!
  12. Adam276 Gingerbread May 24, 2019
    Hmm, i'm on my PC and not mobile and it's loading fine.
    If it worked for you taking $100 off or whatever voucher you used, I guess that means these vouchers work on phones too! :)
  13. meatandy Nougat May 24, 2019
    I'm pretty sure you can't use two discounts in the same transaction, either you use your student discount or your referral points discount not both.
    Adam276 likes this.
  14. Adam276 Gingerbread May 24, 2019
    meatandy
    I'm pretty sure you can't use two discounts in the same transaction, either you use your student discount or your referral points discount not both.​
    oh that I know. $100 off the 7 pro is better than $35.
    I mean I never knew those refer a friend $100 vouchers were able to be used on phones too. I thought it was only for charger, cases and so on. So I saved them since I never needed $100 of chargers and cases
    Does region matter as someone told me he was only able to use on cases and stuff and not a phone. I'm so confused.
  15. meatandy Nougat May 24, 2019
    I would attempt to check out and claim your referral points if the system doesn't let you then contact customer service.
    Adam276 likes this.
  16. dcmcc24 KitKat May 24, 2019
    dcmcc24, May 24, 2019 :
    The vouchers do not work on phones. I know from experience. Only accessories and stuff like the back pack
  17. camohan Marshmallow Moderator May 24, 2019
    camohan, May 24, 2019 :
    You can use it only against the accessories and gear and not against the device.
    Currently there are 2 options available in case one wants to use the referral points to get a device viz., 50% off on 6t it 100% off on 6t, which requires a huge sum of points. Those are specific vouchers only for one against device.
    All other options are available for use against accessories and gears only. There are further options here, voucher to get specific accessories only or a sum of discount against any accessories. For example there is an option to redeem. Points against car charger, the voucher so generated can be used only while checking out car charger. There is a say $50 discount voucher on accessories, such can be used against any accessories or gear.
    @meatandy i can confirm the page has issue. Informed the team.
  18. Adam276 Gingerbread May 24, 2019
    Got it, so unless you have the points to straight buy the phone from referral, the $ vouchers are only for cases, chargers, audio and bags and so on, and not to be used against a phone purchase. So much conflicting information, even from OP support.
  19. meatandy Nougat May 24, 2019
    Thank you .
  20. camohan Marshmallow Moderator May 24, 2019
    Yes you got it right. Currently even the phone option is specific to op6t only.
    The referral system is very specific to community and not related to the usual hardware, software thing. Probably that's the reason they don't have much information.
    Adam276 likes this.
