3
Oneplus 7 Pro Android 11 Phone App Issues
  1. OPOinviteless
    Gingerbread Apr 23, 2021
    OPOinviteless , Apr 23, 2021 :
    This worked for me too! Thanks!
  2. davidr1280
    Donut Apr 23, 2021
    the_o2 likes this.
  3. the_o2
    OnePlus 9 Series Expert Community Expert Apr 23, 2021
    the_o2 , Apr 23, 2021 :
    Good to know that 👍🏻
    Artemus. likes this.
  4. yannou91180
    Cupcake Apr 23, 2021
    yannou91180 , via OnePlus 7 Pro , Apr 23, 2021 :
    Bonjour j'ai fait la nouvelle mis à jour aujourd'hui est je trouve que quand on fait la supercharge mais plus longtemps a recharger le téléphone qu'avant ? Est-ce que c'est normal ?
  5. #25
  6. danieldasilva
    Donut Apr 23, 2021
    danieldasilva , Apr 23, 2021 :
    Bummer. Out of curiosity, what is your phone model (from the "About phone" menu)?
  7. #27
  8. Artemus.
    Community Hero 2020 Apr 23, 2021
    the_o2 likes this.
  9. O1586217063979 , via OnePlus 7 Pro T-Mobile , Apr 23, 2021 :
    This wasn't meant to indicate that it was compatible with the GM1915. Only to show that it is an issue with some OP7Ps.
  10. #30
  11. danieldasilva
    Donut Apr 23, 2021
    Thanks. My device model is GM1917 and I also experience the same issue on 11.0.0.2. I know of at least another user on GM1917 who also has the same issue and disabling the bluetooth hearing aid service did not fix it for them.
    I can't try this workaround at the moment because I have rolled back to OS 10. I think I'll keep it for the time being.
  12. sampson.p.1
    Cupcake Apr 26, 2021
    sampson.p.1 , Apr 26, 2021 :
    This worked for me for first call after stopping HearingAidService and rebooting. After one call, it returns to the speaker phone only mode.
    davidr1280 likes this.
  13. ngcard
    Eclair Apr 28, 2021
    ngcard , Apr 28, 2021 :
    I'm starting to think switching to LineageOS might be something to consider...
  14. danieldasilva
    Donut Apr 28, 2021
    danieldasilva , Apr 28, 2021 :
    Try this: Go to Settings → System → Accessibility and turned on “Hearing Aid Compatibility”.
    I would try the workaround I mentioned above before switching OSes.
  15. sampson.p.1
    Cupcake May 2, 2021
    sampson.p.1 , May 2, 2021 :
    Tried "Hearing Aid Compatibility" on and off. Rebooting either setting. Still likes to open up speaker phone only when making or answering calls which is not useful. I'm not going to try an OS change unless this goes on for much longer as I can use my bluetooth ear bud things for privacy.
    FYI - I am running 11.0.0.2.HD01AA on a model HD1913
  16. V1619991953620
    Cupcake May 2, 2021
    V1619991953620 , May 2, 2021 :
    That speaker phone kicking in on incoming calls is a pretty hard to deal with bug. The sound is coming out of the bottom speaker only, not both speakers. The speaker phone button does nothing. I assume the actual speaker phone has both speakers kick in - top and bottom. I also can no longer can use my custom made headphone cable with the built in mic, since when I use my open-back headset the person on the other end's voice is so horribly blasted loud coming out of the headset it's feeding back into my inline microphone, causing a horrible echo for the person at the other end. And there is NO way to turn down the volume of the person I'm speaking with. The volume rocker does nothing and I see no other settings. It only goes full blast volume, causing a terrible feedback loop, making my $2500 Audeze LCD i4 headphones and expensive custom made headset cable useless for phone calls. I've spent hours trying to find a fix for this. I think this will be my last Oneplus phone, because this is intolerable. I have to depend on my phone for my making a living.
  17. davidr1280
    Donut May 11, 2021
    davidr1280 , via OnePlus 7 Pro , May 11, 2021 :
    While this works, it's only a temporary fix for one phone call. After that, it's back to the loud speaker.
  18. davidr1280
    Donut May 11, 2021
    How are you rolling back to 10? Are you side loading it?
    #38
