2
[Submitted] OnePlus 7 pro Android Q beta - Bluetooth not working
  1. Vincent Rincon
    Cupcake Aug 16, 2019
    Vincent Rincon , Aug 16, 2019 :
    Bluetooth audio stopped working after update. I can pair, but when I try to push to a speaker it doesn't work. I've tried forgetting then reconnecting the device and rebooting.
    Z1562185322852 and ImASH89 like this.
  2. Danieljk91
    Donut Sep 7, 2019
    Danieljk91 , Sep 7, 2019 :
    I'm in the same boat as you! I am on Verizon. Hopefully somebody has a solution
    Z1562185322852 likes this.
  3. NologyAndStuff
    Cupcake Oct 22, 2019
  4. Danieljk91
    Donut Oct 22, 2019
    Danieljk91 , Oct 22, 2019 :
    still no fix for mine... i have it hooked up via usb-c to a 3.5mm for the music.... my phone calls work PERFECTLY on Bluetooth, though.. but my car won't even show the phone as an option for a multimedia audio source. just the aux input
  5. NologyAndStuff
    NologyAndStuff , Oct 22, 2019 :
    I saw someone say disable netflix and hd audio for car but am not seeing that option anywhere but am not currently connected to my car. I will try later and report if these work.
  6. NologyAndStuff
    Cupcake Oct 23, 2019
    NologyAndStuff , Oct 23, 2019 :
    I was able to get music to play by turning media audio off then back on in the Bluetooth device settings twice now. Hope this helps until they find a permanent fix.
  7. Danieljk91
    Donut Oct 25, 2019
    Danieljk91 , Oct 25, 2019 :
    the latest update that just came through fixed it for me!
  8. NologyAndStuff
    Cupcake Nov 1, 2019
    NologyAndStuff , Nov 1, 2019 :
    Are you on beta?
