Oneplus 7 pro back glass damaged via OnePlus 7 Pro
  1. Saifu147
    Cupcake Nov 14, 2020
    Saifu147 , via OnePlus 7 Pro , Nov 14, 2020 :
    I have damaged my oneplus 7 pro back glass with a metal object. The glass is scratched but isn't broken. Anything to fix it? Any liquid? Adhesive? Or any other thing? also if i replace it with after market back glass, is there any difference between the two? or is it all the same?
  2. drl431
    Community Hero 2020 Nov 14, 2020
    drl431 , Nov 14, 2020 :
    You could just apply a skin, such as dbrand or others.
    Artemus likes this.
  3. Saifu147
    I can but i want to fix this. I have damaged it for few days without knowing what i was doing. Now i want to fix it. If you could help me on how to fix it please.
  4. drl431
    Contact OnePlus customer service to arrange getting the phone to a service center. Check the support tab in the OnePlus website and scroll down to repair pricing.
    Artemus likes this.
  5. Saifu147
    I'm from Pakistan. There's no service here in Pakistan. And I can't afford to send my phone to oneplus somewhere else.
  6. drl431
    That does make the skin plan more appealing. It is only cosmetic damage. But you could check with local 3rd party repair centers.
    Artemus likes this.
  7. J4t1np4r3kh
    OnePlus Accessory Tester Nov 15, 2020
    J4t1np4r3kh , via OnePlus 7 Pro , Nov 15, 2020 :
    Bare in mind, having the back glass panel replaced will not be cheap.
    As about adhesives, there are a few available that claim to do the trick, but can't really vouch for these 🤷‍♂️
    P1599045743562 and Artemus like this.
  8. Sebush
    Froyo Nov 15, 2020
    Sebush , via OnePlus 7T , Nov 15, 2020 :
    There are special resins that fill cracks in glass. Automattive windshield repair kits come to mind. Then you have those cheap glass repair things on **********.
  9. Bittoo06
    Jelly Bean Nov 15, 2020
  10. Saifu147
    Cupcake Nov 15, 2020
    Saifu147 , via OnePlus 7 Pro , Nov 15, 2020 :
    It's gonna cost around 40$ if i order from alibaba. Because we don't have alibaba official service here. We have to use 3rd party.
  11. Saifu147
  12. Saifu147
    Thanks mate. I will try this one on a regular glass first xD
  13. J4t1np4r3kh
    When I was talking about cost I was referring to the service centre cost. Getting it replaced independently most likely may be cheaper
    P1599045743562 likes this.
  14. Saifu147
    Okay now if i replace the back glass. Will there be any difference between the original and after market back panel? Or are they all the same?
  15. J4t1np4r3kh
    Depends on how good of an aftermarket item you can find. If it's practically exact and it's replaced properly, I highly doubt you'll notice a difference at all 🤷‍♂️
  16. Saifu147
    Thanks mate. I'll still order the 11$ one instead of the 5$ back glass. Just to be sure.
    J4t1np4r3kh likes this.
  17. J4t1np4r3kh
    Good luck bud! Let us know about your success rate, may help others for the future 🔥
  18. Saifu147
  19. #19
  20. Bittoo06
    Jelly Bean Nov 16, 2020
