9
OnePlus 7 pro battery charging issue
  1. redfloyd
    Cupcake Jun 26, 2019
    redfloyd , Jun 26, 2019 :
    Yes, OnePlus have cheated many new users. Many many are not getting the charging speed as they claim!! What are you guys doing about this? I am confused and don't want to deposit my new phone only to get it repaired. They won't even replace it. I was an apple phone user and feel that I have made a big mistake switching over to OnePlus.
    #81
  2. TysonSW
    Froyo Jun 26, 2019
    TysonSW , Jun 26, 2019 :
    Are you charging with or without a case on the phone?
    A case would definitely increase the temperature.
    #82
  3. redfloyd
    I don't see how 'with or without case' charging can have any major effect on charging speed.
    #83
  4. TysonSW
    Froyo Jun 26, 2019
    The charging system throttles the charging current if the device gets to hot.
    #84
  5. redfloyd
    yes but the fact I'm in an AC room will have no affect on charging speed whether or not I'm charging it with the phone case or not.
    #85
  6. TysonSW
    Froyo Jun 26, 2019
    I have had numerous devices from different manufacturers that I noticed throttling on if the device gets hot. And with a case the device will have bigger problems with dissipating the heat since it creates an extra barrier for the heat to go through.
    So try to charge with and without a case from the same start percentage and you should see some difference.
    #86
  7. redfloyd
    but my device isn't getting overheated and still it's not going from 0-50 in 20mins. it's going on till 33-35%.
    maybe it's related to the home voltage / earthing etc. I'm not too sure what's going wrong for all those facing this issue.
    also, I'm not using the phone while it's charging and no background app with serious battery draining are installed. also, I've wiped my data and tried charging on safe mode but no better results.
    #87
  8. TysonSW
    Froyo Jun 26, 2019
    Can you confirm that you have tried without a case and with the warp charger?
    I'm sorry if there was something lost in the translation
    #88
  9. redfloyd
    #89
  10. Vinay1310
    Cupcake Jun 30, 2019
  11. G1551604390761
    #91
  12. Zvoni
    Froyo Jun 30, 2019
    Zvoni , Jun 30, 2019 :
    bro learn to write and speak
    #92
    redfloyd likes this.
  13. N1562088553894
    Cupcake Jul 2, 2019
    N1562088553894 , Jul 2, 2019 :
    Even I am facing the same issue. I have got my phone replaced from the store but the problem is still there
    #93
  14. N1562088553894
    Cupcake Jul 2, 2019
    Even I am facing the same issue. But this is not at all acceptable. The companies major marketing strategy is 50% in 20mins , which is not at all happening. Some serious steps should be taken on this
    #94
  15. Zvoni
    Froyo Jul 2, 2019
    Zvoni , Jul 2, 2019 :
    yeah i am getting really pissed actually.
    #95
