125
OnePlus 7 Pro battery/heating feedback thread
  1. mackmiller974
    Froyo May 24, 2019
    mackmiller974 , May 24, 2019 :
    OnePlus 7 Pro battery tips for people who are having issues. Turn your brightness to around 70-80% or less if you can view your phone comfortably. Brightness is the biggest battery drainer of all. Turn off location and Bluetooth until you need it. Restrict the Apps you do not need notifications from running in the background. Turn on battery optimizer at around 20%. I've used these tips and I get around 7 hour's of screen on time each day.
    danutz_timo likes this.
  2. Radeon962
    KitKat May 24, 2019
    GoLeafsGo163, ashutoxh and robinevers like this.
  3. mackmiller974
    Froyo May 24, 2019
    To save battery life obviously... If you do not need location and Bluetooth then turn it off until. If you do not need notifications from certain apps then do not let them run in the background. None of these things are very important and it will help you save significant battery life.
    ashishjena and Radeon962 like this.
  4. Radeon962
    KitKat May 24, 2019
    Radeon962 , May 24, 2019 :
    I realize that but why be required to go through the hassle.
    if you really want to save battery turn the refresh rate down to 60hz rather than 90hz.
    https://www.google.com/amp/s/www.an...s-7-pro-battery-life-90hz-display-985616/amp/
  5. B_Wrath
    Nougat May 24, 2019
    B_Wrath , May 24, 2019 :
    There is already a pinned battery thread.
    Please use it for further discussions.
    Don't create redundant threads.
  6. MassiveRS
    Froyo May 24, 2019
    MassiveRS , May 24, 2019 :
    battery life for me seems solid! the above is after my 2nd charge!
    QHD+
    90Hz
    Automatic Brightness
    WiFi on and connected for the most part
    Location always on
    Bluetooth on and connected intermittently
  7. K1558219876520
    Gingerbread May 24, 2019
    K1558219876520 , May 24, 2019 :
    True.
    Radeon962 likes this.
  8. darkwingduck20
    Cupcake May 24, 2019
    darkwingduck20 , May 24, 2019 :
    I'm sure this has been discussed before. I used to get about 2 days of battery life on the One Plus 6T. now, with the One Plus 7 Pro, a bigger battery, I'm only getting about 8 hours. anyone else having issues? Any fixes?
  9. Aziz_Amin_Oneplus
    Jelly Bean May 24, 2019
    Aziz_Amin_Oneplus , May 24, 2019 :
    It must be on 90Hz, you cannot get 2 days on it, just go to Refresh Rate in Display and select 60Hz, that should do the trick for you, with that Wipe Cache from Recovery mode and you will have good battery life and if this do not help then give your feedback to Oneplus, they will be bringing update patch for resolving the battery issue. I have Oneplus 5T and I am still rocking 2 days of battery life with 6 hours of SOT and this is the New Oneplus Phone so it should not be a problem ;)
    darkwingduck20 likes this.
  10. Y1558638781344
    Donut May 24, 2019
  11. Y1558638781344
    Donut May 24, 2019
    Y1558638781344 , May 24, 2019 :
    mackmiller974
    Restrict the Apps you do not use. turn off your location and Bluetooth. Make sure your brightness is around 70-80% or less. Screen brightness is the biggest battery drainer of anything. I keep my brightness at around 75% and restrict the Apps that I do not need notifications from in my background and I get almost 7Hours of screen on time each day. What percentage do you keep your brightness at.​
    how can I know how many procentages my brightness is?
  12. mackmiller974
    Froyo May 24, 2019
    You can't find an exact percentage but 100% is full brightness so just estimate it from that. I would just use it at the lowest brightness level you are comfortable with.
  13. Y1558638781344
    Donut May 24, 2019
    ok thanks
  14. I1557987513702
    Eclair May 24, 2019
    I1557987513702 , May 24, 2019 :
    I received my phone on May 25, went through the software upgrade, added all my apps, switched on dark mode in all the areas that I could, set the display to 60 hrz, and my first experience from full battery has been great. My main metric is screen-on-time. I am at 4 hours 32 minutes with 50 percent charge remaining.
  15. Y1558638781344
    Donut May 24, 2019
  16. Navi09ns
    Cupcake May 25, 2019
    Navi09ns , May 25, 2019 :
    If anyone here is facing battery drain or temperature issues with their oneplus 7 pro, I had posted about it on the telegram channel, and figured out that shifting data from my 6t to 7pro using their switch app was probably the cause, it left quite a few apps damaged, they were behaving wierd, had strange wakelocks and temperatures would spike out of no where,
    I did a complete reset of the phone, restored my app through google cloud and everything seems A-okay as of now, battery back up seems at the very least 10-20% better, with no spike in temps.
    Will get back with a day experience tomorrow, until then, if anyone facing similar issue can try this
    (After reset)
    (before reset)
    AndiTheBassman likes this.
  17. fonefreek
    fonefreek , May 25, 2019 :
    Glad that worked for you but unfortunately for me I originally transferred all of my data using Google and so far my battery is horrible. Draining so fast I won't be able to keep it. Had 100% this morning and already at 65% with about 30-45 minutes of usage and the screen is only using 60hz refresh.
    Between this battery issue and now the phantom touch issues I'm probably going to have to return it. I'm using the 12gig ram version so I wonder if the extra RAM is hurting the battery as well.
  18. Navi09ns
    Hey man. I doubt ram would have a detrimental effect on battery back, if at all any, and before you return it, try this.
    Update to latest ota, backup every thing. Reset your phone entirely. Complete wipe, not just phone settings, wipe phone's media storage as well.
    After that log in and set up everything again, it might help.
    Also i have also kept my default display at auto and 90hz. It helped me out.
    Do check for background location scanning their bluetooth and wifi, turn of default printing as well.
    It could be due to oneplus switch or the latest ota update, am not sure. But it seems to have been resolved as of now for me.
    Try this and get back with your experience. It should help others as well.
    All the best.
  19. fonefreek
    Thanks. I may try that but just don't have the time to do it right now. I read that disabling NFC cures/helps the phantom touch issues and that seemed to work but I need to know this is an issue that they can fix with a software update and not an unfixable hardware issue. Hopefully they will release some information soon about a fix otherwise I'll probably have to return it and wait for them to iron things out before repurchasing it.
    Love the phone and hope they can get things fixed before I have to return it and wait. Still have a 5T which still works great so glad I haven't sold it yet.
  20. Navi09ns
    Sure man. Hope it works out for you. I sold my 6t so all am left with is 7 pro and it got solved in my case. Or so it seems for now atleast. In case you decide to reset. Tell us your experience after that.
