52
OnePlus 7 Pro battery/heating feedback thread
  1. rspettit
    Cupcake May 29, 2019
    rspettit , May 29, 2019 :
    Does taking photos consume battery life so much due to the utterly inferior software design for the 48 mexapixel camera module? Given that OnePlus has a history of bad camera software, I had really hoped that the new "flagship" would sport a camera that could at least keep up with my cellphone from 2 years ago. Unfortunately, not.
  2. Y1558638781344
    Donut May 29, 2019
    Y1558638781344 , May 29, 2019 :
    The phone is new which means that its going to have updates for the camera and + i dont think people buy oneplus phones for taking only pictures
  3. Filipe_C_E
    Gingerbread May 29, 2019
  4. Grilled_Trout
    Gingerbread May 30, 2019
    Grilled_Trout , May 30, 2019 :
    It has been observed by many that 90hz does reduce battery life by quite a bit. So yeah, you either give up the 90hz or the battery life. Can't have both it seems :(
    Now the IP rating. Having the phone IP certified means OnePlus will have to be much more responsible and thorough in the manufacturing process. Also, I am more concerned with dust, especially ones that lingers inside my pockets. That pop-up camera is a disaster waiting to happen with dust. And there are already reports of seeing dust being collected inside the pop-up mechanism.
    Wireless charging is convenient. Also you don't get the warp charge benefit unless you use the proprietary cable and adapter. Wireless charging also helps reduce wear and tear on the USB-C port.
    You see... It was not such a big deal when OnePlus phones were cheaper than the competing flagships by a mile. But after the $120 price hike, now it is no longer the case any more. Now it is starting to feel like being compromised, even if the missing features are ones I don't necessarily need.
    Oh, and I don't consider buying OnePlus phones for the camera. I have accepted the reality, so of the camera comes out great, then it just becomes icing on the cake.
  5. Y1558638781344
    Donut May 30, 2019
  6. swiftden
    Eclair May 30, 2019
    swiftden , May 30, 2019 :
    1440p + 90hz. Light theme, Auto brightness, Location, BT, Sync, everything on. All day on Wifi. 1559204632321.jpg 1559204638533.jpg
  7. mrukanshjaiswal
    Cupcake May 30, 2019
    mrukanshjaiswal , May 30, 2019 :
    I have recently purchased one plus 7 pro. I don't understand y battery drains so fast.
    what to do ? Plz suggest
  8. Wahoux
    Lollipop May 30, 2019
    Tobikage likes this.
  9. mrukanshjaiswal
    like I have fully charged my phone. but after couple of usage of whatsapp and Facebook and daily essential apps battery drains rapidly. without using much of it.
  10. Tobikage
    Nougat May 30, 2019
    Tobikage , May 30, 2019 :
    With the limited info you have provided , the only solution is...contact support.
  11. Tobikage
    Nougat May 30, 2019
    Do you know that you can see a graph of battery drain and how much percentage each app used and screen on time in settings ?
  12. mrukanshjaiswal
    yes but everything seems to be ok. phone charging doesn't even last for a full day
  13. B_Wrath
    Marshmallow May 30, 2019
    B_Wrath , May 30, 2019 :
    Share the battery stats screenshot.
  14. Swejuggalo
    KitKat May 30, 2019
  15. Tobikage
    Nougat May 30, 2019
    How much Screen On Time are you getting ?
  16. pablofg1978
    Spanish POC Assistant Head Moderator May 30, 2019
    pablofg1978 , May 30, 2019 :
    Thread merged
  17. OG_Kauie
    Eclair May 30, 2019
    OG_Kauie , May 30, 2019 :
    Going from Auto Switch in resolution and 90hz to FHD+ and 60hz shot up my screen on time from 7 hours to 8.5 hours. I think it would benefit the users if OnePlus included a switch to the more power efficient display setting as part of the battery saver. If not, atleast a quick toggle to swap between 60hz and 90hz would be well appreciated.
    TheGlissando likes this.
  18. V1511602123642
    V1511602123642 , May 30, 2019 :
    I feel the battery doesn't really do justice to the phone, anyone else feels the same?
    Been a user of One Plus Series, but this one has scope for improvement
  19. Sargo
    Ice Cream Sandwich May 30, 2019
    Sargo , May 30, 2019 :
    Higher resolution screen size and refresh rate all have consequences
  20. paul67™
