60
OnePlus 7 Pro battery/heating feedback thread
  1. yl62319
    Cupcake Jun 6, 2019
    yl62319 , Jun 6, 2019 :
    I am afraid to leave it plug in over night just in case it over heat and the battery catches on fire
  2. KTaylor62
    Honeycomb Jun 6, 2019
    KTaylor62 , Jun 6, 2019 :
    haven't had any battery heating issues at all and I've been charging overnight. but i also don't charge it everyday.
  3. bhavinder001
    Gingerbread Jun 6, 2019
    bhavinder001 , Jun 6, 2019 :
    Hi Sashka
    With every mAh increase battery size the weight of phone increases .. OP7 pro is already above 200 gms..you dont want a brick in your hand !!
  4. bhavinder001
    screen time is way above 1 hour..I am getting 5 hours on OP7 pro!!
  5. bhavinder001
    apply RMA...dont take any chances.
  6. Sashka_1323
    Eclair Jun 6, 2019
    Sashka_1323 , Jun 6, 2019 :
    what about s10+??? Is it so big, no! but battery is larger))
  7. bhavinder001
    does it have mechanical parts ? No. In order to fit more parts you need space..so hopefully now you can understand. Also consider the price difference between the two phones. 3. it is just 4100mAh not something like 5000 mAh
  8. Sashka_1323
    Eclair Jun 6, 2019
    xiaomi k 20 pro....
  9. bhavinder001
    I knew you would bring K20 pro in the discussion..but please note that brand value/after sales support matter a lot. Also note that they have cut some corners + the ads on MIUI.
    FYI - K20 Pro also have 4000mAH battery as it is also having mechanical parts :)
  10. Sashka_1323
    Eclair Jun 6, 2019
    smaller size and far far cheaper
  11. bhavinder001
    You say that the K20 Pro is a good phone and value for money, I will be the first one to agree. But, do not compare it with the OnePlus 7 pro.
    It is necessary to understand the ideology behind a product. OnePlus is a premium brand it gets you flagship features at not-soflagship prices.
    It is impossible to compare Oxygen OS to MIUI, I honestly cannot use MIUI.
    Another important thing to note is that the 2 phones are meant for 2 different kinds of users.
    The K20Pro is not an industry first, Redmi has always anxiously waited for OnePlus to launch their phones and then it comes out with its cheap marketing game.
    It's not striving for innovation it is trying to be OnePlus, if that is what they want then I want to be a frontrunner.
    Did Redmi do something mind-blowing? Nope.
    Does it have an industry first 90 Hz display? Nope.
    Does it have bloat free software experience, that the tech world loves? Nope.
    A OnePlus user will buy a OnePlus and a Xioami user will buy a Xioami
    Albeit it's the most expensive OnePlus yet but it still is cheaper than what the big boys offer.
    I would like if OnePlus priced their phones below 45k but let's be real I don't need a 90HZ display, I'm totally happy with the OnePlus 7 - the same uncompromised phone with top of the line specs and it is worth every penny.
    Do the math!
  12. Kadhirvelan D
    Cupcake Jun 6, 2019
    Kadhirvelan D , Jun 6, 2019 :
    My Phone is getting hot right now. it's getting hotter and hotter by every minute. I have stopped all the apps running behind.
    this is the second time
    please help at the earliest.
  13. Y1558638781344
    Donut Jun 6, 2019
    Y1558638781344 , Jun 6, 2019 :
    restart
  14. Dari4sho
    Cupcake Jun 6, 2019
    Dari4sho , Jun 6, 2019 :
    Hey guys, I just registered because I can almost watch the percentages fall and found this thread. I'm not doing anything because I'm working, but my phone drained from 100% to 16% at this very moment almost by itself. SOC is below 2 hours. Dunno if I'm doing something wrong - got this phone for 2 days now. Ah btw, 60hz and FHD+, NFC off, location off, wifi off, BT active. Edit: after reading a bit more, I gotta chill more. Hope this... settles..
  15. MarkoBatrac
    MarkoBatrac , Jun 6, 2019 :
    That is really bad..Try factory reset
  16. skysfreedom
    Cupcake Jun 6, 2019
    skysfreedom , Jun 6, 2019 :
    I suggest that Oneplus should hide the 60Hz option to Developer Options. The 90Hz looks so good and you don't want any normal user to miss it. I would say it would be a pity for a normal user to switch to 60Hz and forget to change it back...
    I have been heavily using OP7 PRO since it released with 90Hz. The battery is very reasonable especially with the 30w wrap charger. I don't have any low-battery anxiety with this.
    If you are a power user, you could always make a switch to 60Hz in Developer Options.
    Eventually, the adaptive refresh rate option should be the way to go. Wait and see.
  17. Rahul_89
    Donut Jun 7, 2019
    Rahul_89 , Jun 7, 2019 :
    My phone is heating while on charging... What is the solution for that?
  18. DarkoRoje
    Cupcake Jun 7, 2019
    DarkoRoje , Jun 7, 2019 :
    The battery life is unfortunately not very good on the 7plus pro. I struggle to get 4hours SOT.
  19. Y1558638781344
    Donut Jun 7, 2019
    Y1558638781344 , Jun 7, 2019 :
    DarkoRoje
    The battery life is unfortunately not very good on the 7plus pro. I struggle to get 4hours SOT.​
    Turn off Bluetooth when ur not using it same with location, turn on dark theme, take a screenshot of battery usage.
  20. Bryn Hickin
    Cupcake Jun 7, 2019
    Bryn Hickin , Jun 7, 2019 :
    http://imgur.com/a/2jKHSTE
    My OnePlus 7 Pro arrived today however as New Zealand isn't a supported country by OnePlus the retailers here (got mine from PB Tech) parallel import the phone.
    Due to this the original Warp Charge 30 plug is a UK standard fitting not New Zealand. The retailers therefore pack a New Zealand plug which is the NZ standard fitting.
    I added the specs written on each charger in the imgur album linked above. Will the NZ Oppo charger be charging my OP7 Pro to the maximum Warp Charge 30 capable speed?
    If no, can I achieve the maximum Warp Charge 30 speeds in anyway e.g using an adapter on the UK plug or will the adapter slow down charging speeds/melt under the current draw?
    Thank you!
