119
OnePlus 7 Pro battery/heating feedback thread
  1. Aayush1010
    Cupcake Jun 10, 2019
    Aayush1010 , Jun 10, 2019 :
    Hello team, I have just brought the OnePlus 7 and its been like 2 days and while charging it getting hot a little bit so, is it normal or what bcoz as I know new mobiles never get hot while charging.
    Also, I have one doubt related to speaker.
    In bottom 2 speaker only one(left) gives me a high sound/volume and another (right one ) has a low volume.
    Kindly help me with the confusion with this.
  2. vinay_reddu
    vinay_reddu , Jun 10, 2019 :
    Hi, I too bought OP7 last week, and I haven't observed any hearing issues while charging it in use so far. I believe if the 2 bottom sm grills, only one is speaker, and thev other is only for symmetry, and not a speaker grill. however, I'm experiencing few issues with touch, where I'm seeing some freezes and unresponsiveness.
  3. Maverick2.0
    KitKat Jun 10, 2019
    Maverick2.0 , Jun 10, 2019 :
    Every phone gets hot while charging. Absolutely normal.
  4. Aayush1010
    Thanks let me see 2-3 days more if it gets more hot then I should get it check by service center.
  5. saikiran1211
  6. Wahoux
    Lollipop Jun 10, 2019
  7. saikiran1211
    saikiran1211 , Jun 10, 2019 :
    but 6t is better than 7 pro when compared to this heat
  8. Wahoux
    Wahoux , Jun 10, 2019 :
    but 7 pro is more powerful...
  9. Y1558638781344
    Donut Jun 10, 2019
    Y1558638781344 , Jun 10, 2019 :
    Oneplus 7 Pro has a bigger screen + QHD+
  10. hearty128b
    Gingerbread Jun 11, 2019
    hearty128b , Jun 11, 2019 :
    my first day With the Phone
    it going to be better over time?
    here is the screenshot
    thanks for the help!
    I'm running the 9.5.7 update
  11. derLenno
    The Lab - OnePlus 6 Reviewer Jun 11, 2019
    derLenno , Jun 11, 2019 :
    Everything above 5hrs of screen on time beats most phones that are out. 3.5hrs and your phone is still half full - you are good to go!
    Edit. Just saw that your last full charge was more than a day ago. Even better!
    hearty128b likes this.
  12. hearty128b
    thanks man!
    also.. I used the 90hz and Qhd!
    so..
    I've noticed that the sdandbay time was great!
    less great in use!
  13. D1558293428781
    Cupcake Jun 12, 2019
    D1558293428781 , Jun 12, 2019 :
    the op7pro i have heats up rather substantially while playing games, (durango, lost lands on high settings) Has anyone else have this experience?
  14. UnicornZ
    Ice Cream Sandwich Jun 12, 2019
    UnicornZ , Jun 12, 2019 :
    Seems this phone is having one of the best battery.. With qhd and 90hz I am getting 7hr SOT.. massive
  15. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jun 12, 2019
  16. dna111
    Froyo Jun 12, 2019
  17. pgrey
    pgrey , Jun 12, 2019 :
    Does anyone else see a "single, huge drop" typically a couple of hours after fully-charging, while mostly on stand-by?
    I haven't installed any new apps, or made any significant changes, that I can think of, since 9.5.5, where this did NOT occur.
    I'm seeing a pattern a bit like this:
    - charge to 100%
    - take off charger, do a few things, set the phone aside while wrapping things up, maybe an hour or two
    - phone is maybe at 98%, at this point, or similar.
    - go for a 2-3 hour road-ride, and when I get back, it's still at say 96%.
    - set the phone down, again in Stand-by, for a bit, maybe 30 minutes.
    - grab the phone to sync my workout watch, or similar, and notice that it's now at 89% (roughly), dropping 7% in those 30 minutes of "StandBy", with no actual "Battery use", in the percentage graph.
    I see things like GoogleMessenger using 1%, and WiFi or Cell using 1-2%, adding up to maybe 3-4%, total, and my "battery graph" has a BIG drop, right after I get home (that 30 minute window).
    I sort of thought it might be some sort of "big sync", given that it's back on WiFi when I return, but I sure don't see it, if I look at the WiFi throughput for the device (I have an SMB setup at home, so I can track "all sorts of minutiae", in terms of network throughput, with a high-degree of accuracy (mostly Cisco and Unifi gear).
    My "workout watch app" is VERY background restricted, intentionally, I don't want "real time" updates or similar, I'm plenty happy to do a post-ride sync, every time. It's not registering any data usage either, in that "big drop window", so it's not that, before anyone asks.
    I wonder what the heck IS causing the "huge drop" in StandBy, three times since moving to 9.5.7, 3 days ago now, it's happened every day, same exact pattern?
    And yep, I've also checked my app-data-usage, during the same time-period, that's usually my first "go-to" when I see weird stuff like this, it's almost always something using a LOT of data, in that timeframe. Not so much, this time...
    @KeepTransisting I agree, overall the battery-life is really good, given the specs of the h/w, particularly the "view-ability" of the screen, in almost any light.
    I just wish I knew what was causing my single, daily, big-drops, so I could adjust things (or perhaps file a bug, with some pretty big logs, to cover the 30 or so minutes) to prevent it.
  18. RAYUU
    Eclair Jun 12, 2019
    RAYUU , Jun 12, 2019 :
    It has been a little over 24hrs since my 7P arrived. I have no issues related to heat, nor longevity. 7 Pro 9.5.7 12GB, with auto brightness and LTE.
  19. KCYEOH
    Cupcake Jun 13, 2019
    KCYEOH , Jun 13, 2019 :
    I just got my phone a week ago, for the best behavior of charging, should i always wait till the battery % drop till less than 10% only charge it? Or it doesn't really matter at what level of the percentage of the battery you do the charging?
  20. Y1558638781344
    Donut Jun 13, 2019
    Y1558638781344 , Jun 13, 2019 :
    KCYEOH
    I think it's like recommended to not go lower than 10 to 20 procentages and then not charging it over 80. and I understand the not going lower than 20% but not the fact that it's not recommended to go over 80 % but I guess if u wanna u can do it like that but I just charge my phone when it's around 15 - 20 %
    Hackerspy and KCYEOH like this.
