35
OnePlus 7 Pro battery/heating feedback thread
  1. sud92
    Cupcake Jun 16, 2019
    sud92 , Jun 16, 2019 :
    Using the pro for a week now. Is it normal for battery to drain 10% on standby .
  2. B.Balu
    Eclair Jun 16, 2019
  3. Swejuggalo
    Jelly Bean Jun 16, 2019
    Swejuggalo , Jun 16, 2019 :
    Mine drains like 3-4 % during night (like 6 hours standby). Wifi/mobile/location on.
    Always scanning on bluetooth and wifi is off. I also restricted Facebook background behavior. Other than that everything is "normal" in regards to settings.
    Hard to tell what's normal without knowing details on installed apps and various setting you may have done or haven't done.
  4. sud92
    I have been facing this problem for the last 3 days before that it was 3-4% max. i have not installed any new apps during these time using qhd resolution in auto switch mode
  5. Swejuggalo
    If you click on "view detailed usage" in Battery. Check both normal view with just the apps and the full device view with radios and stuff included. Nothing abnormal visible there?
    Mine look like this currently.
  6. sud92
  7. Swejuggalo
  8. sud92
    thanks will try it..
  9. TriducPhamdo
    TriducPhamdo , Jun 16, 2019 :
    when I play games I can feel heat coming from the top of the phone, especially the front camera spot is that normal?
    JB Roesch likes this.
  10. Swejuggalo
    Depends how hot it becomes
    If you use a case of some kind the heat finds its way where there is the least isolation. Forward trough the screen and trough gaps/holes in the cover. The camera area will become kind of a hotspot on the back since a case covers the rest. If you don't have a case on the hotspot should be slightly to the side of the camera.
    Under the black backward L shaped area there is the SD855 chip. This pic is a nice way to see inside your phone [e]1f609[/e]
    Full resolution found here: https://www.ifixit.com/News/oneplus...um=feed&utm_campaign=Feed: Ifixitorg (iFixit)
  11. Y1558638781344
    Donut Jun 16, 2019
    Y1558638781344 , Jun 16, 2019 :
    Google play services draining battery. I have already wiped the cache on the whole phone and turned off auto sync
  12. April A
    Cupcake Jun 17, 2019
  13. ArKaN.
    ArKaN. , Jun 17, 2019 :
    Hello,
    (GPS Probmems)
    I used this week first time Waze (Gps maps) on my car and as usual, I use with a plugin (Original OnePlus warp charger) to not discharge my phone. The problem that I found is that the phone goes so hot that almost burn your hand. I observe this when I touch the screen (after about 30 min) and at that moment I stop using Waze and for me this it is a real problem. After this, I did some tests because I am thinking that the problem was from warp charge because the battery was at 65% when I start to use and I try again at 99% and was the same overheating problem.
    What to do ???
    Thx
  14. AnantDags
    Froyo Jun 18, 2019
  15. Swejuggalo
    Jelly Bean Jun 18, 2019
    Swejuggalo , Jun 18, 2019 :
    Try wiping cache of the launcher. Maybe even wipe data if you are willing to reconfigure it.
  16. X1560810892803
    Cupcake Jun 19, 2019
    X1560810892803 , Jun 19, 2019 :
    Hi All,
    I'm using OnePlus 7 Pro from last 2 week and from the first day i'm facing battery issue. While using the phone it gives me screen on time near about 6 to 7 hour through out the day and some time needs to charge the device twice a day. I hope OnePlus will fix this issue in next update because i have seen this complain in may other forum and they are highlighting this issue on its peek.
  17. kevinkoyani
    kevinkoyani , Jun 19, 2019 :
    yes this is right
  18. mgriyaz
    Eclair Jun 19, 2019
  19. J1559599091156
    J1559599091156 , Jun 19, 2019 :
    i got 5+- hours SOT.
    With games it's even less, 4+- . For example my 2 years 5t get easy 5-6 hours with games on screen all time.
  20. Y1558638781344
    Donut Jun 19, 2019
    Y1558638781344 , Jun 19, 2019 :
    well do you have NFC Location Bluetooth always on even when you don't use them? Do you have an app that uses more than normal?
