71
OnePlus 7 Pro battery/heating feedback thread
  1. Swejuggalo
    KitKat Jun 16, 2019
  2. sud92
    Cupcake Jun 16, 2019
    sud92 , Jun 16, 2019 :
    thanks will try it..
  3. TriducPhamdo
    TriducPhamdo , Jun 16, 2019 :
    when I play games I can feel heat coming from the top of the phone, especially the front camera spot is that normal?
    JB Roesch likes this.
  4. Swejuggalo
    KitKat Jun 16, 2019
    Swejuggalo , Jun 16, 2019 :
    Depends how hot it becomes
    If you use a case of some kind the heat finds its way where there is the least isolation. Forward trough the screen and trough gaps/holes in the cover. The camera area will become kind of a hotspot on the back since a case covers the rest. If you don't have a case on the hotspot should be slightly to the side of the camera.
    Under the black backward L shaped area there is the SD855 chip. This pic is a nice way to see inside your phone [e]1f609[/e]
    Full resolution found here: https://www.ifixit.com/News/oneplus...um=feed&utm_campaign=Feed: Ifixitorg (iFixit)
  5. Y1558638781344
    Donut Jun 16, 2019
    Y1558638781344 , Jun 16, 2019 :
    Google play services draining battery. I have already wiped the cache on the whole phone and turned off auto sync
  6. April A
    Cupcake Jun 17, 2019
  7. ArKaN.
    ArKaN. , Jun 17, 2019 :
    Hello,
    (GPS Probmems)
    I used this week first time Waze (Gps maps) on my car and as usual, I use with a plugin (Original OnePlus warp charger) to not discharge my phone. The problem that I found is that the phone goes so hot that almost burn your hand. I observe this when I touch the screen (after about 30 min) and at that moment I stop using Waze and for me this it is a real problem. After this, I did some tests because I am thinking that the problem was from warp charge because the battery was at 65% when I start to use and I try again at 99% and was the same overheating problem.
    What to do ???
    Thx
  8. AnantDags
    Gingerbread Jun 18, 2019
  9. Swejuggalo
    KitKat Jun 18, 2019
    Swejuggalo , Jun 18, 2019 :
    Try wiping cache of the launcher. Maybe even wipe data if you are willing to reconfigure it.
  10. X1560810892803
    Cupcake Jun 19, 2019
    X1560810892803 , Jun 19, 2019 :
    Hi All,
    I'm using OnePlus 7 Pro from last 2 week and from the first day i'm facing battery issue. While using the phone it gives me screen on time near about 6 to 7 hour through out the day and some time needs to charge the device twice a day. I hope OnePlus will fix this issue in next update because i have seen this complain in may other forum and they are highlighting this issue on its peek.
  11. kevinkoyani
    kevinkoyani , Jun 19, 2019 :
    yes this is right
  12. mgriyaz
    Eclair Jun 19, 2019
  13. J1559599091156
    J1559599091156 , Jun 19, 2019 :
    i got 5+- hours SOT.
    With games it's even less, 4+- . For example my 2 years 5t get easy 5-6 hours with games on screen all time.
  14. Y1558638781344
    Donut Jun 19, 2019
    Y1558638781344 , Jun 19, 2019 :
    well do you have NFC Location Bluetooth always on even when you don't use them? Do you have an app that uses more than normal?
  15. J1559599091156
    sure bt, gps, NFC always on. same at 5t which have 6+ SoT with games and same S10+ which gets almost 9+ hours easily with my usage. 7pro for me needs 2 charges a day, like 3 years old iphone 5s with dead battery.
    But 7pro smooth ofcourse...... =\
  16. Y1558638781344
    Donut Jun 19, 2019
    7 pro has QHD 90hz display ofc
  17. J1559599091156
  18. unicornZ
    Honeycomb Jun 19, 2019
  19. F1560965562727
    F1560965562727 , Jun 19, 2019 :
    hlo there my oneplus 7pro have lot of issue like ( auto rotation is not working ( AUGMENTED REALITY NOT WORKING ) (FRONT CAMERA FALL DETECTOR NOT WORKING )...
    all problem stated past 3 days ...I don't know why...any software issue...
  20. ArKaN.
    Cupcake Jun 20, 2019
    ArKaN. , Jun 20, 2019 :
    Anyone with clear info about my abobe problem with GPS ??
    After this last update i have many many problems: Bluetooth comunicationsis doping for no reason, finger print sensor some times is not activating and need to enter the code, i receive notification that i need to restart the phone to be able to see again some notification, etc... etc ... loocks like the fast and good phone start to not be so good ... please fix asap ... and let the stupid camera how it was noone is using so much to sacrifice all the rest for camera improvements ....
