35
OnePlus 7 Pro battery/heating feedback thread
  1. wmAkuma
    Cupcake Jun 23, 2019
    wmAkuma , Jun 23, 2019 :
    I installed pubg to test on this phone today and after 1 game, about 27 min, my battery dropped from 99% to 50%.. is this normal?
  2. Narayan_Shrestha
    Froyo Jun 23, 2019
    Narayan_Shrestha , Jun 23, 2019 :
    No its not normal. It's a huge fall. I can play Pubg with extreme fps for 3.5 hrs at 90hz refresh rate and Auto resolution on 4g network.
    wmAkuma likes this.
  3. Hackerspy
    Eclair Jun 23, 2019
    Hackerspy , Jun 23, 2019 :
    I have been using the phone since early June. Never had a screen on time larger than 3-4hours. I have got WiFi, Data and Bluetooth always on.
    I'm trying last days to check if my mi band 3 is consuming by heavy..
    I have around 88 apps (including stock ones) and have restricted background usage of all games..
  4. P1527361100672
    Donut Jun 24, 2019
    P1527361100672 , Jun 24, 2019 :
    hi I have a OnePlus 7pro and I just installed fortnite whenever I play fortnite my phone heats up a lot can someone help?
  5. B_Wrath
    Marshmallow Jun 24, 2019
    B_Wrath , Jun 24, 2019 :
    Playing high graphic resource demanding game of heating up the phone!? What kind of sorcery is that!?
  6. P1527361100672
    Donut Jun 24, 2019
    is this a reply from support it's sounds little bit rude.
    because I posted this comment to OnePlus 7pro support and if you are not one of them then don't reply!
  7. Neddard
    Lollipop Jun 24, 2019
    Neddard , Jun 24, 2019 :
    This is a user community forum. Just other users such as yourself, not an official OP support channel.
  8. Manyeko Sharingan
    Froyo Jun 24, 2019
  9. TheGlissando
    Donut Jun 24, 2019
    TheGlissando , Jun 24, 2019 :
    Sharing stats from using Battery Saver from a full charge which I do regularly.
    Here's a few settings I've modified as well.
    -Disabled Body Sensors privilege from Google Play Services
    -Disabled Ambient Display options
    -Disabled YouTube screen controls on lock screen
    -Disabled YouTube previews playing on home screen
    -15 second screen timeout
    -Black background/gray accent
    -60HZ / FHD / Natural / No color enhancement
    -Auto brightness off/ adjusted manually
    -Bluetooth used when driving, otherwise off
    -Wifi off unless needed, mostly LTE usage
    -Location is always off
    Model: GM1910 12GB/256GB
    Memory runs about 30% on average.
    Same Settings + Battery Saver From Full Charge + Night Mode On From Full Charge
    Battery Saver Estimate
  10. G_Michał_Sojka_Vwus
    Cupcake Jun 24, 2019
  11. RAYUU
    Eclair Jun 24, 2019
    RAYUU , Jun 24, 2019 :
    High and extremely low voltages are bad for lithium ion, but most ignore the underlying science. In any case, deep discharges reduce the max # of cycles a battery can supply. There's a reason why some devices show poor endurance at year 1, 2, 3, etc. On Windows wear level can be found via commands or progs, whereas most androids don't reveal cycle count nor wear level.
  12. dhawal.d7
    Gingerbread Jun 25, 2019
    dhawal.d7 , Jun 25, 2019 :
    After the 9.5.8 update the Google play services is draining battery excessively. Tried clearing the data and cache multiple times but still no improvement.
    UKIan likes this.
  13. fuzzmo
    Cupcake Jun 25, 2019
    fuzzmo , Jun 25, 2019 :
    I had a similar-ish issue after the update. My phone was always slightly warm and my battery was draining faster than normal. What seems to have worked for me (as I saw Play Services creeping up) was to turn off location services on Whatsapp. Apparently some apps request location info via Play services so that would be the first thing to check for. Turning that off and rebooting brought my battery usage back to normal and the phone feels cool to the touch. Hope this works for you. Outside of that you might need to check some guides as to what to pin down next.
  14. P1515905379630
    P1515905379630 , Jun 25, 2019 :
    What I usually do is to go into the App settings and to remove permission for Play Services for "Modify System Settings". That alwas helped me.
  15. Scherpenseel
    Jelly Bean Jun 25, 2019
    Scherpenseel , Jun 25, 2019 :
    Give the battery a couple of days/cycles to settle. This is always needed after a big update.
  16. stark2991_PL
    KitKat Jun 25, 2019
    stark2991_PL , Jun 25, 2019 :
    Clearing data for the app?
  17. Sir_Pool_de_Float_MD
    Eclair Jun 25, 2019
    Sir_Pool_de_Float_MD , Jun 25, 2019 :
    Agree with above on location. Check which apps have used your location recently, and reset them. Pokemon Go uses location, obviously, and the notification comes from Google Play Services, so I suspect a bad app is pulling location too frequently.
  18. dhawal.d7
    Gingerbread Jun 26, 2019
    dhawal.d7 , Jun 26, 2019 :
    thanks for the help. tried this let's see if it helps.
  19. dhawal.d7
    I don't have Pokemon go installed. however i have disabled the location permission for apps that used it. let's see if this helps.
  20. sandor.barna
    Cupcake Jun 26, 2019
    sandor.barna , Jun 26, 2019 :
    Im on 9.5.8 Oxygen OS. No2 I have abou 3 hours SOT and only browsers or chat softwares runs. With prvisious versions i can do 8 hours sot. 9.5.8 is not so good. :(
