27
OnePlus 7 Pro battery/heating feedback thread
  1. M1559156982425 Donut Jul 16, 2019
    Lycan_Strife likes this.
  2. Swejuggalo Jelly Bean Jul 16, 2019
    Swejuggalo, Jul 16, 2019 :
    I have written to a guy with a faulty unit. Even 10 minuts of phone call was a problem. Major heat issues. He got it replaced and the issues disappeared.
    I always benchmarks my devices thermal dissipation qulites with that app I mentioned. Best phone I had on that test was Nokia 8. Nearly the whole phone was a big lump of aluminium heatspreader so no real surprise [e]1f609[/e] Sony XZ3 started to clock down abit too much for my taste before full test time.
    The test should be run without a case on though.
    No noticeably issue with full load on all CPU cores for 15 minutes on my device atleast.
  3. M1559156982425 Donut Jul 16, 2019
    M1559156982425, Jul 16, 2019 :
    which test? and even something wrong with my device, I live in Moscow, some people buying this phone in Europe and bringing here, so no service or anything else ((
  4. Swejuggalo Jelly Bean Jul 16, 2019
    https://play.google.com/store/apps/details?id=skynet.cputhrottlingtest
    In normal ambiant temperatures it should be capable to run this test for 15 minutes without clocking down a lot (or atleast only very little) or warn about overheating.
    Try it without a case on and see what results you get after 15 minutes.
  5. vighnesh js Eclair Jul 17, 2019
  6. Abraham Amos Donut Jul 18, 2019
    Abraham Amos, Jul 18, 2019 :
    i found a way to improve my battery life,use your phone till 0%,then charge overnight ( dont switch on your phone),im getting 2 more hours SOT,idk if this is the case with other devices
  7. dna111 Froyo Jul 18, 2019
    dna111, Jul 18, 2019 :
    its Not recommended fully drain the battery
  8. Y1558638781344 Donut Jul 18, 2019
    Y1558638781344, Jul 18, 2019 :
    shouldn't go lower than 10 to 15 procentages. maybe it helps if you just turn off ya phone you charge it dunno but shouldn't go lower than 10 to 15 procentages
  9. rzozaya1969 Froyo Jul 18, 2019
    rzozaya1969, Jul 18, 2019 :
    I have a question regarding charging the OP in general. I have OP 6. Can I use any charger for the device? Or do I need to use the Warp charger? What happens if I use the warp charger on the OP 6, which supports the Dash charge? What if I use a standard charger?
  10. vighnesh js Eclair Jul 18, 2019
    vighnesh js, Jul 18, 2019 :
    may the charging ic get damaged ,or your battery may be got damaged
  11. vighnesh js Eclair Jul 18, 2019
  12. Abraham Amos Donut Jul 18, 2019
    just do it once,thats all,just to calibrate the battery
  13. Abraham Amos Donut Jul 18, 2019
    only once,just to calibrate the battery
  14. Thomas Savoie Cupcake Jul 18, 2019
  15. Lycan_Strife Froyo Jul 19, 2019
    Lycan_Strife, Jul 19, 2019 :
    Again... If anybody wants to test out a game called TorqueDrift - play that for like 5 min or so... And tell me what your batt.temp is and especially your cpu temp. Thanks.
    oneplus 7 pro (12gb)
  16. I1562849121512 Cupcake Jul 19, 2019
    I1562849121512, Jul 19, 2019 :
    I am facing heating issue in my OnePlus 7 pro 8GB variant. It heats up a lot while charging, streaming videos, using any app etc. Heating level seems more than the normal level. Please fix my issue.
  17. vighnesh js Eclair Jul 19, 2019
    vighnesh js, Jul 19, 2019 :
    iam using the same
    but i didnt face any heating issue,heats up only while playing pubg at high graphics
  18. Thecon Cupcake Jul 20, 2019
    Thecon, Jul 20, 2019 :
    Which is the configuración of your device?
  19. Thecon Cupcake Jul 20, 2019
    How DIF you do that? I never achieve that time of screen
  20. vaibhavmunot Froyo Jul 20, 2019
    vaibhavmunot, Jul 20, 2019 :
    I still get this. Qhd and 60hz
    Thecon likes this.
