35
OnePlus 7 Pro battery/heating feedback thread
  1. Y1558638781344
    Donut Aug 16, 2019
    Y1558638781344 , Aug 16, 2019 :
    can you link it for me
  2. Swejuggalo
    Jelly Bean Aug 17, 2019
  3. Y1558638781344
    Donut Aug 17, 2019
  4. Swejuggalo
    Swejuggalo , Aug 17, 2019 :
    Seems like you missed a letter. com.asksven.betterbatterystats_xdaedition
  5. Y1558638781344
    Donut Aug 17, 2019
    Y1558638781344 , Aug 17, 2019 :
    thanks I got it but another question, do I have to keep it on in background
  6. Swejuggalo
    It runs in background
  7. Y1558638781344
    Donut Aug 17, 2019
  8. Swejuggalo
  9. huseyinozbektas
    Cupcake Aug 17, 2019
    huseyinozbektas , Aug 17, 2019 :
    unfortunately oneplus 7 / 7+ device idle consumes a lot of charge iphone devices this problem does not happen this problem is not software or hardware I do not know how to fill the night charge 100% in the morning when I look at airplane mode 7% and 8 is not going to understand the problem of spending two days in idle
  10. Swejuggalo
    huseyinozbektas
    unfortunately oneplus 7 / 7+ device idle consumes a lot of charge iphone devices this problem does not happen this problem is not software or hardware I do not know how to fill the night charge 100% in the morning when I look at airplane mode 7% and 8 is not going to understand the problem of spending two days in idle​
    Some of the idle drain comes from RAM boost. But not for everyone
    And a lot of users has issues with Google play services. But that is not a problem limited to Oneplus
  11. huseyinozbektas
    Is there no solution to this?
  12. Swejuggalo
    You can disable RAM boost and see if that makes a differance for you. Google "fix google play services battery drain" if that is a problem for you.
    I have mentioned a few things you can do here.
    http://bit.ly/2ZzdsP8
  13. huseyinozbektas
    I understand it has been nice and descriptive but I do not know how to take root ios I have passed from android device but I would have been better for it if the video would be better thanks anyway.
  14. Swejuggalo
    No root is needed. I mention "ADB or root" with "ADB" as a clickable link to installation information and download links. All the stuff I have done myself is without root. Set up and use adb is all you need. There exist plenty of guides on that and probably in many languages too.
  15. Y1558638781344
    Donut Aug 17, 2019
  16. Swejuggalo
    Y1558638781344
    O yeah and now how can I see what apps have wake lock thing​
    I posted a link to a guide in my guide. There is probably more info if you google "how to use BBS" http://bit.ly/2KpL8IE
    Leave it on battery a night. Check partial wakelocks and alarms.
    Can look something like this. This is daytime usage though.
    Leaving it a night, maybe charge it some before bed time, will reset the data and only measure from that point onward. You can also set a custom ref. That way you will see only what is happening during night. Some apps can go crazy and add a ton of wakelocks. If you can't live without the apps and still want them despite causing drain you can try to ignore wakelocks. I mentioned a tool in my guide that helps with identifying package names.
  17. Shevach
    Eclair Aug 18, 2019
    Shevach , Aug 18, 2019 :
    I am wondering is this is normal wake like activity I think a few are triggering to much like "CastDeviceController" and "wake:CollectionChimeraSvc”
  18. Y1558638781344
    Donut Aug 18, 2019
  19. Swejuggalo
    Jelly Bean Aug 18, 2019
    Swejuggalo , Aug 18, 2019 :
    This is my night. My wifi was on but I guess the sleep optimization kicked in and disabled it during some hours of sleep. It was on when I woke up the phone.
    Some extra activity from Google play seems to be the new normal. I hope they fix it soon. Not all activity is google fault though. Some apps can trigger it due to using location based functions and stuff. With my tweaks and with beta on Google play services this is what I get.
  20. Y1558638781344
    Donut Aug 18, 2019
    Y1558638781344 , Aug 18, 2019 :
    So do I have any wake locks or is everything good. just battery got worse or something
