38
OnePlus 7 Pro battery/heating feedback thread
  1. Swejuggalo
    KitKat Aug 18, 2019
    Swejuggalo , Aug 18, 2019 :
    Well you seem to have battery saving mode active on the screenshots and you haven't reset the measurement by setting a custom ref or temporary charge it before bed so it only records sleep time.
    The drain might be very differance if you do not have battery saving mode on. You only have it active during night or almost all the time? Would be more interesting with a measurement without battery saving on.
  2. Y1558638781344
    Donut Aug 18, 2019
    Y1558638781344 , Aug 18, 2019 :
    I don't use battery saving but it might be that I have a setting somewhere that it turns it on
  3. Y1558638781344
    Donut Aug 18, 2019
    Swejuggalo
    The drain might be very differance if you do not have battery saving mode on. You only have it active during night or almost all the time? Would be more interesting with a measurement without battery saving on.​
    wait that icon it isn't battery saving if ur talking about that it's just shows it when I open the app.
  4. Swejuggalo
    KitKat Aug 18, 2019
    Ah I see [e]1f60a[/e]
    Don't get a symbol on my phone when opening BBS. Made me wonder.
    I don't see a problem with your stats. Just need to set a ref or unplug it right before bed to see a true idle drain.
  5. Y1558638781344
    Donut Aug 18, 2019
    okay I'm just gonna charge before bed and then just unplug
  6. Morgan MLGman
    Cupcake Aug 18, 2019
    Morgan MLGman , Aug 18, 2019 :
    Hello,
    I have a question about on how to best charge the OnePlus 7 Pro. Usually, I charged my previous smartphones in a way to keep them between 20% and 80% whenever possible to preserve battery lifespan.
    Now I know that there are devices which are protected to allow charging to 100% without battery degradation by featuring a larger battery that's artificially locked to the rated capacity.
    Does anyone know if a full charge affects the battery a lot on the OnePlus 7 Pro?
    Are there some official charging and battery recommendations to keep the battery relevant as long as possible for this device?
    Thanks!
  7. Y1558638781344
    Donut Aug 19, 2019
    Y1558638781344 , Aug 19, 2019 :
    I put my phone to charge but it didn't reset so I tapped on the set custom ref time and nothing happened
  8. Swejuggalo
    KitKat Aug 19, 2019
    Swejuggalo , Aug 19, 2019 :
    You only see the custom ref if you select it. The app should have reset after unplugging the charger unless you activated measurement during charging. There is also a unplug reference point you can select.
  9. Y1558638781344
    Donut Aug 19, 2019
    pretty nice
  10. Swejuggalo
    KitKat Aug 19, 2019
    Only that awful Google Play Services. But it could be triggered by location polls from apps for example. Some stuff is hard to avoid if you want the full functionality on some apps.
    And there is also known issues with Google Play Issues.
  11. Y1558638781344
    Donut Aug 19, 2019
    yeah ik this is the only reason I want apple rn. and I don't have location on just had it for couple minutes to check when bus is coming
  12. Swejuggalo
    KitKat Aug 19, 2019
    As it strange as it sounds some stuff can actually cause higher drain if location is off (I don't know when an what though). I always have location on myself.
  13. Y1558638781344
    Donut Aug 19, 2019
    ok I'm going to try keep it on the whole time tomorrow
  14. Y1558638781344
    Donut Aug 19, 2019
    The problem is that google play services would drain about 4% and turning on location didn't help cuz I charged the phone and now it has been couple hours and it has already drained 2%.
  15. Y1558638781344
    Donut Aug 20, 2019
  16. ujjwalbassi1255
    Cupcake Aug 22, 2019
    ujjwalbassi1255 , Aug 22, 2019 :
    I have op7pro 12gb variant.
    It worked perfectly for 1 month. After that, whenever my battey percentage is going down below 10% or even equals to 10% it drains from 10% to 0 and switches off like barely in 5-6 minutes. I do the working on background apps and everything as i am an android developer but i never dealt with a problem that is related to battery.
    What should i do? i tried to recalibrate my battery as directed from many websites, that letting your phone die and then switch it on again and then let it die again and then charge to 100%. I did it 3-4 times but still the issue is there. What should i do?
    ashe6 likes this.
  17. leopoldoismael
    leopoldoismael , Aug 22, 2019 :
    Normally one full charge for me lasts for 2 full days (if not playing games). Just have the refresh rate at 60Hz, wifi, data, location, bluetooth always on, normal activities like email, social apps, chatting, some reddit scrolling, the long lasting I've had so far.
  18. ashe6
    ashe6 , Aug 22, 2019 :
    Hello,
    Just wanted to know how many people also noticed a battery drain since the last update (9.5.11) and if anyone has found a fix.
    In my case, nothing weird appear in the battery settings (not Google service related) but I recently noticed a decreased SOT (4-5h) with the same usage.
    Hopefully, it will be solve in next update.
    Thanks for the feedbacks
    Regards,
  19. AlexanderMtz5T
  20. Swejuggalo
    KitKat Aug 22, 2019
    Swejuggalo , Aug 22, 2019 :
    Several users including me got an improvement if disabling RAM boost. Try it and reboot.
