36
OnePlus 7 Pro battery/heating feedback thread
  1. sidharth.javvadi
    Gingerbread Sep 22, 2019
    sidharth.javvadi , Sep 22, 2019 :
    while playing PUBG ...
    one plus 7 pro getting over heated than my previous phone one plus 6
    miracle! right
    bye bye one plus
    ONE PLUS END!
    best gaming phone - APPLE iPhone
  2. Shakthivignesh N
    Cupcake Sep 24, 2019
    Shakthivignesh N , Sep 24, 2019 :
    I'm the one also not satisfied with this battery life even 60
    hz!! & FHD+ Resolution!! Not up to mark
  3. nitesh nitesh
  4. Boris saxe
  5. M1569423987734
    Cupcake Sep 25, 2019
    M1569423987734 , Sep 25, 2019 :
    This is my second 7 pro, traded the first in on a warranty for the same issue but I don't think it's the phone anymore. Current phone has been in use for several days and the standby battery life is awful.
    2 hours unplugged from full charge, 19 minutes of screen time and it's dropped to 70% battery. Android system battery usage seems very high, and I can barely make it to lunchtime at work. Any advice is appreciated. Phone is running Oxygen OS 9.5.10.GM31CB Screenshot_20190925-080024.jpg Screenshot_20190925-080018.jpg Screenshot_20190925-080007.jpg
  6. payashlakhe
    Cupcake Sep 26, 2019
    payashlakhe , Sep 26, 2019 :
    the battery is draining heavily in OnePlus 7 Pro after Android 10 update. Not even a half day after a charge and the battery is already 60%. 40% down before half day. Before the update, the battery would last full day stretched to night but now it doesn't seem to.
  7. Cervantes
    Lollipop Moderator Sep 26, 2019
    Cervantes , Sep 26, 2019 :
    Hi
    after an update the battery needs to be recalibrated
    For someone of opinion you should upload a screenshot of:
    battery charge
    battery use
    Please You read the first post
    The battery thread is a thread of questions and/or commentary
    Thread merged
  8. payashlakhe
    I had searched for the thread. didn't list in my search so created a new thread. please optimize help OnePlus optimize the thread search with tags and keywords.
  9. Cervantes
    You use: community app or website
  10. payashlakhe
  11. Cervantes
    if you have no results using the search engine
    One way to search, is to review the forum, by the model of your phone
    One Plus 7 series: you have sticky threads at the top
    One plus 7 series has subforums, to see them, select + and choose for example: One plus 7 pro General Support
    Thanks, Best regards, Cervantes
    payashlakhe likes this.
  12. Y1558638781344
    Donut Sep 27, 2019
    Y1558638781344 , Sep 27, 2019 :
    hey, do I don't have a screenshot rn but i can put later today after I have used my phone a little but the battery has a bad standby because I literally have fhd and I dont use my phone much, but I get around 5-6h somewhere between there. where. before I used auto switch and I got around 7h 20m.
  13. KamalJat808
    Cupcake Sep 27, 2019
    KamalJat808 , Sep 27, 2019 :
    After installing OB2 on OP7 pro battery is draining fast as before , may be new software update may be took good news about this matter.This is observed approximately 7 days of phone use by mine.
  14. h.pednekar
    Cupcake Sep 28, 2019
    h.pednekar , Sep 28, 2019 :
    Android 10 OB2
    Heating issues while normal use like Instagram, Facebook, Outlook basic apps
    Battery draining faster than earlier with similar amount of use
  15. G_Szalay_Tamás_zRVW
    G_Szalay_Tamás_zRVW , Sep 28, 2019 :
    Hey Guys. Im using accubattery pro and it says my batttery's healt is 91%. its just a few month old. says 3600mah max capacity. is it normal? isnot this kind of battery issue in the warranty? can i open any warranty case for repair? btw my old phone xiaomi mi8 after a year use still at 100% healt . :/ im a bit disappointed in oneplus.
  16. rahulnigam95
    Eclair Sep 28, 2019
    rahulnigam95 , via OnePlus 7 Pro , Sep 28, 2019 :
    After the Android 10 update I can see that the battery consumption increased a lot (based on my normal usage before and after Android 10 update). Is this many people are facing?
  17. Y1561911217179
    Froyo Sep 28, 2019
    Y1561911217179 , Sep 28, 2019 :
    highly disappointed ..even after spending 50k plus on one plus 7 pro..one plus unable to provide us macro mode ,portrait mode in video and 960 superslomo ..which all present in low price newly introduced mob i.e one plus 7 T...just in a span if 3 months they have made one plus 7 pro an older version phone. they r itself killing their flagship mobile...diaappointtteeeddd
  18. KamalJat808
    Cupcake Sep 29, 2019
  19. flexier
    Froyo Oct 2, 2019
    flexier , Oct 2, 2019 :
    What exactly are you expecting in a macro mode more than what the Pro mode gives you. You get a focus at a distance of about 6-8 cm (same applies to the Standard mode. How close you want to take the phone? Besides there are physical limits of the built in lenses. You would need a special macro lens to get any closer!
  20. flexier
    Froyo Oct 2, 2019
    In addition to my previous reply...
    REAL 960fps super slow motion requires special hardware...
    "A native 960fps slow motion mode requires hardware to go with it, namely a camera sensor with embedded DRAM. By attaching super-fast memory to the camera sensor, the phone is able to save all the frames generated by the 960fps mode. Traditional smartphone storage (e.g. UFS 2.1 and eMMC) simply isn’t able to keep up with the sheer number of frames being produced in this mode, making the embedded DRAM an integral part of the process.
    What if your phone isn’t using a camera sensor with embedded DRAM? After all, these sensors are in the minority. Then manufacturers generally use software processing/interpolation to deliver 960fps super slow motion, adding duplicate frames to a lower frame-rate video in order to give the impression that it’s a smoother, 960fps clip.
    The finished product will technically be running at 960fps, but half or more of those frames are simply copies rather than being unique, like in a real 960fps video. It’s akin to motion smoothing modes seen on today’s TVs, duplicating frames to deliver 60fps content....
    ....however current crop of 48MP camera sensors don’t appear to offer native 960fps capabilities at all."
    https://www.androidauthority.com/real-960fps-super-slow-motion-999639/
    So there is very likely no 960fps hardware support in the OnePlus 7 Pro. And a software solution is basically a gimmick.
    Having said this, 1080p at 240 fps and 720p at 480 fps isn't too bad. If you want to go into slow motion video, get a proper camera.
    Y1561911217179 likes this.
